Originally Posted by
djEmpire
Hi everyone!
I've been using my Technics 1200MK2 tables professionally for over 30 years. After all the reliable years of sonic bliss, the tables will finally compliment my HI-FI system. But before I add it to the rest of the gear, I would like to make it sound as 'neutral' as possible. One of the ways is implementing an external Power Supply Unit. The other is fluid damper injection.
So far I'm I'm installing a new tonearm, and Cardas Litz tonearm wires. Even a new coat of pearl white paint!
TIA! Serf
Another thing you should consider is peeling off that ill applied factory rubber mat on the underside of your platter and replacing it with a layer of Dynamat Extreme.
We the willing, working for the unknowing, are doing the impossible for the ungrateful.
We have done so much for so long with so little, we are now qualified to do anything with nothing.
