Results 1 to 6 of 6
Thread: Audio greetings from Germany - Going active with Najda DSP
    I'm Hardy.
    Default Audio greetings from Germany - Going active with Najda DSP
    Hi all,
    my name is Hardy and I'm a music lover and an audio DIY guy from Germany.
    I've realised a few speaker projects, but since about 17 years I'm reworking from time to time my latest DIY big 3-way D'Appolito speaker (based on SEAS chassis) x-over network.
    Recently I've converted it all to an active setup, based on the Najda boxed DSP and a Rotel RMB-1506 6-channel amp.
    As I wasn't happy with the out of the box sound of this setup, I've started to experiment with different opamps in the Najda DSP.
    I'm very curious to hear about your experiences with going active and especially with the Najda DSP and recommendations for opamps or other sound tuning ideas.
    Opamps I've tested so far:
    - LM833 (original Najda ingredient) -> didn't convince me at all
    - LM4562 -> better, but still doesn't fulfil my expectations
    - AD8066 -> (currently waiting for the opamp delivery. I've read a lot of positive things about the AD8066) to be checked
    - your recommendation?
    Cheers,
    Hardy
    hi and welcome Hardy. There are a few guys who have gone active here, so sure you will get info and opinions
    I'm Neil.
    Welcome to AoS
    Regards Neil
    Hello Hardy. Welcome to AOS.
    DIY projects are popular here. If you have any 'on the go', you could feature them with a blog in the Gallery section or show them in The Drawing board area.
    Take a look around the site and feel free to join in any chat that interests you.
    Enjoy the forum,
    Geoff.
    I'm Tom.
    Hi
    Seeing that you use the Najda DSP, how do you use it, digital in or analog in?
    Have you build your own or did you buy the boxed one?
    Do you encounter the same things as I do with the Najda, that is overload on the digital input, something I 've never seen with the Behringer DCX2496...
    I hope you dont mind all these questions,
    Regards, Tom (tojoko)
    Welcome to AoS Hardy
    Enjoy the Forum
