Tungsol 6550 vs TAD 6550 ?.
Hi,i'm looking for some advice on output valves I had a set of Tungsol 6550 in the amp before and liked them because I found them quite musical but now fancy a change has anyone compared the Tad's to the Tungsol's,i would love to know there impressions.
Thanks for looking
Happy Listnering
Tim
Tim, I have not used a TAD 6550 but it appears to be Shuguang 6550A selected for TAD. Both the Shuguang KT88 and 6550 are very nice, I find the midrange of these to be a bit better than the TS 6550. The TAD might also be a bit more rugged than the TS although it is nowhere near the quality of the GE 6550A they copied.
- You may not post replies
- You may not edit your posts
Forum Rules
