Results 1 to 7 of 7
Thread: Stuck platter?
    I'm Matt.
    Default Stuck platter?
    Hi all,
    Having setup one of my SL1210 mk2 again I've found that the platter on one of them simply will not remove. Pulling off the other one is no hassle at all.
    Has anyone come across this difficulty before and solved it?
    Cheers
    may have jammed a bit on spindle. try a slight jiggle as you lift or tap spindle a little. had this on a few tts.
    Try packing cardboard under the platter rim all round, in order to apply a bit of upward pressure and then tap the spindle/shaft moderately with a hammer, using a piece of wood to protect the spindle tip. That usually works.
    I'm Matt.
    Thanks gents, will let you know the outcome. I think the packing will be better here, I pulled and wiggled very hard a number of times! (ooo err).
    a gentle tap with a panel pin hammer will work wonders.
    PRE
    I'm Mick.
    Small squirt of WD40 then leave for a while. Then pull up on the platter as someone lightly taps the spindle. Put a cloth over the spindle so you dont mark it.
    Technics SL1210 MK2 fully rebuilt and repainted. Ortofon 2M Black Cart, Isonoe isolation feet , MN bearing and Funk Firm platter upgrade, Oyaide RCA Tone Arm and speaker cables, Jelco SA-750D Tonearm. Oyaide HS-TF Carbon headshell, MCRU Linear External PSU, High Fidelity Crystal glass turntable matt, Blue LED upgrade, Denon AVR-2808CI Amp, Bowers and Wilkins DM602S3 Speakers,
    Black Rhodium Jazz power cables for amp and turntable, Firebottle mk2 Phono Stage.
    I'm Hugo.
    give the spindle a good knock-knock, preferably with s bit of wood or hard plastic.
    Worst case scwenario- hair drier around the spindle and pull
    https://www.youtube.com/watch?v=hS1w0hA01go at around the 1 minute mark
