Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 61
Thread: Rcm cleaning with a moth - what bits are best?
  1. #31
    I'm Graham.
    For water I would recommend this http://pureklenz.co.uk/purified-wate...FUWVGwod0aYNDQ as BP/EP grade water is manufactured to a defined specification,DI is not and the QC is generally rubbish,or in some cases non existent.I've worked on 100's DI/BP systems over the years and it's not uncommon to find diluted HCL and NaOh being passed to service from DI systems with the client being totally unaware as they had zero QC in place and relied on the plant alone,also DI will have high bacterial count's,not good for non alcoholic mixes as the bugs will grow quickly,see here http://forums.stevehoffman.tv/thread...rading.399260/
    IPA can be purchase on line and I use dishwasher rinse aid as a surfactant.I tried lart du son but found it left a residue and needed another rinse with pure water to remove it,never bother with the IPA mix,once is enough.
    Analogue. Basis signature 2200,Basis Vector 4.Koetsu Red,Koetsu SUT,NVO SPA 11.
    Digital. Denon 2900,Jolida FX 11
    Amp. Pathos Logos,Minidsp dirac 22A.
    Speakers. Amphion Xenon.
    Airlink CBS 2000 bps
  2. #32
    Hey, I good idea, thanks Grant. 😁
    Sent from my 9001X using Tapatalk
    i usually use my old cdr's the didnt work right or are surplus. you can use 2 to make it a tighter seal as 1 can buckle a little
    I'm Josie.
    Thanks Graham and all for your input. I'll look in to that water...
    BTW, how long do you leave your LP's for before putting them back in the sleeve? Some (including me) used to put them back in almost straight away but some leave them out for 30mins??
    Tannoyista.com
    - Audio Equipment Reviews
    Facebook
  4. #34
    mine are dry when they come off turntable Jo. I just hit them with the ion gun then into sleeves; my fluid is anti static but no harm in adding a blast from the gun too. which I have to say Ive ran out of again
    I'm Alex.
    Hi chaps.
    I've recently got a moth RCM and wondered if anyone can recommend the best in the following:
    Cleaning solution - always heard 'the right one' to be the best but that's now unavailable, what's the next best and where to buy?
    Felt strips - where is the best place to buy? Ebay or other ones? Should these stick to the inside if the tube too?
    Inner sleeves.. Currently using audio works which seem nice and good quality.
    Outer sleeves, which ones are the best? And which ones are second best?
    Any suggestions would be great
    Many thanks
    Jo
    I'm making my own cleaning fluid. 80% distilled water, 20% alcohol (99% pure), plus 5ml ILFORD ILFOTOL surfactant.
    https://photos.google.com/share/AF1Q...ZuTE9vUmtoQ2Jn
    Alex.
  6. #36
    I'm Josie.
    Thanks very much, Alex for that.
    Lol... Ilford, Kodak.. Takes me back to my uni days developing photos in creepy dark rooms.
    I'll certainly keep that in mind and maybe buy some of that too.
    Regarding outer sleeves, which ones are best as in thickness... Most are sold on the thickness in microns.. A bit geeky I know but hey I'm a geeky gal. 😁
    Tannoyista.com
    Facebook
  7. #37
    Get the thickest ones
    think this is the grade I use mostly. its been a while since I got any tbh....there is a thicker 520gm but dont have softeners in which I prefer.
    http://www.ebay.co.uk/itm/50-12-inch...3D262912183722
    I'm jamie.
    hi josie/grant
    if you want to send me a small container i'll give you some of my triton x cleaning fluid already made up so you can try it
    My System
    John Wood KT88 Amp.
    Paradise Phono Stage
    Sony TTS-8000 Turntable.
    PMAT-1010 MK6 Tonearm.
    Ortofon Cadenza Bronze
    Sony X555ES Cd Player
    Yamaha NS1000m Speakers
  9. #39
    Nice offer Jamie. If I find one I will let you know mate. Mine is made with the Ilford. I use about 10ml per litre tho. Find it works better for me. I wont mention my extra ingredient as some will have kittens Trust me it works
    I'm jamie.
    yes ive tried the ilford,imo the triton is better and its much cheaper,and most would have kittens if they new what i did before the vac stage.lol oh the poor misguided fools lol
    My System
    John Wood KT88 Amp.
