yep,you can add 5% iso if you wish,the first 5 pages of is thread give you all the info,its written by a chemist not someone shilling a record cleaning fluid
http://audiokarma.org/forums/index.p...-wrong.689430/
My System
John Wood KT88 Amp.
Paradise Phono Stage
Sony TTS-8000 Turntable.
PMAT-1010 MK6 Tonearm.
Ortofon Cadenza Bronze
Sony X555ES Cd Player
Yamaha NS1000m Speakers
I'm Charlie.
Josie,
My Moth RCM is now at least 20 years old and still going strong.
Don't worry about out of date photoflo. It's just a surfactant and keeps for ages. I have a very old bottle, which I use in my darkroom as well for film development - it's fine.
My RCM mix is (by volume) - 80% distilled water: 20% IPA with about 5 ml of Photoflo per 1L of wash mix. 1L will clean over 100 LPs.
Inner sleeves - depends whether you have printed inner or a plain inner If it's a plain inner, I just use the white poly inners from covers33. If it's a printed inner, I now usually use a separate plain inner for the LP and have the printed inner empty - alternatively I also Nagaoka inners inside a printed inner.
Outer sleeves - usually don't bother - just adds to the shelf inches - important if you have 000s of LPs
Velvet bits for the RCM - just buy from Moth or British Audio Products - just stick onto the horizontal vacuum arm next to the slit - no need to put anything inside.
Charlie
I'm Peter.
For what it's worth, I've tried three mixes (homemade is best) with the right high quality ingredients.
1. The Right Stuff (sample supplied from this forum)
2. THe Jazz Collective recipe (just superb)
3. Project "Wash It" (Very Good)
Plus... as Struth puts it a good Wet Goat.
For me.... others may disagree, Number 2 does it for me at quarter of the cost of commercial stuff.
I'm Peter.
I apologies..... sorry a typo for fluid No 1
The "Right one" ........ not the Right Stuff.
Sorry...... it's an age thing.
Peter
I've got a Pro-Ject RCM and love it. But it's not that different from the Moth. It has some fuzzy lips for the suction tube, but I think come time to replace them, I'll use the VPI replacements. Or perhaps make some from the replacement MoFi fuzz for their record brush.
Which is a good brush, but not my only brush. And expensive! $20 for a rubber block with a fuzzy stick on covering, but it does have a lot of surface area, and does a fair job of scrubbing records.
I use the MoFi fluid too, mainly because it's readily available and it works. Is it the best? I don't know. But I've got the regular wash, super wash, and enzyme wash, and haven't run into anything it didn't clean to my satisfaction. And at $30 a bottle it's not cheap, but a bottle will last a very long time, maybe 200 records or more?
And also I use the MoFi inner sleeves, I've never tried any others, but they seem to work just fine. I bought an RCM starter pack, that included the wash, the brush, and the sleeves, that's how I got into all the MoFi stuff, and it works. Is it best? I couldn't say. But it is readily available.
Thanks very much guys for your help. It's all great advice.
Hmmm.. So which avenue in regards to fluid? I'll have a think.
I always liked the Nagaoka sleeves but at the same time find the a bit fiddly. These analogueworks ones seem to be available and are cheap too.
Does anyone find Nagaoka ones fiddly or is it me? Lol
I ordered some furry lips (ooer) from analogue seduction, they were cheap enough.
The pics I've seen of the moth, the lips curl in to the slot, is that just another way of doing it? I ask because the edges of the strips feel quite rough and could potentially scratch the record?
Sent from my 9001X using Tapatalk
Tannoyista.com - Audio Equipment Reviews
I'm Peter.
Good luck with that - Geoff's older than Methusala
Happy birthday, Peter 😀
