Results 1 to 5 of 5
Thread: Replacement Phone battery supplier??
    I'm Anto.
    Default Replacement Phone battery supplier??
    I was wondering if any peeps out there , can recommend a decent supplier of genuine or indeed comparable , batteries to the Samsung originals,please??
    I have a Galaxy Note 1 N7000. Its old but here in the sticks ,it does everything I need for the minute , except for the battery situation!
    I had 2 batteries ,and have a charger I can put one of the spares in to charge ,whilst using the other in phone.
    Last year I purchased 2 off Fleabag , and one has bulged and the other is not brilliant either !
    For the moment I was going to buy one decent replacement to go with the only really good battery out of he 4 ,I have left
    Seen the Duracell branded one on Duracell Direct , but this whole replacement battery thing is a ruddy nightmare !!
    So many fake and substandard ones about
    So , has anyone a good place they can tip me off about please?
    Thanks
    https://www.amazon.co.uk/ORIGINAL-GT...cement+battery
    supposed to be genuine but not cheap.... Ive used a few of the oem ones and they are cheap enough that you can buy a few. I had a couple of bad ones and a couple that lasted for long time. Trouble is the phone is a good age so Samsung dont make them any more
    The Duracell branded replacements tend to be very reliable. So I would go for one of them.
    I'm Anto.
    That link made me laugh Grant!! It says in non retail packaging and in the smaller description says in Retail packaging
    I might give the Duracell one a go at 19.99 , thanks Stanley
    A few years ago I picked up an Anker double size replacement battery and a bigger back for my samsung s3. works still to this day and gives twice the runtime. Maybe Anker did them for that model too
