Its easy, just find a multimeter and measure without any signal leads connected, from input to output
then output to ground, where the resistances greet each other - the resistance measurement then shown
is the passive devices, true impedance. Each channel Left and Right should ideally be the same.
Where you may be confused is then attaching signal leads, but a passives true impedance is quite simple
reflective of its L pad resistances intersecting, It is after all a resistive divider, in this case variable.
Noting variations occur where they intersect with log or linear types, but at some point they indeed intersect.
So it's fine to repeatedly and regularly mislead AOS members with blatantly incorrect falsehoods shrouded in a bit of technical sounding gobbledygook to make it sound plausible is it? "False news" (to make it topical) welcome but calling it out and ridiculing it not? If it were up to me I'd do something about a trade member repeatedly proffering false information and advice which is very definitely WRONG... or does he have to advise sticking a finger in a mains socket before anything happens?
you know rules jez. similar to football.. play the ball
Thanks for all the info, I only asked to see if there was anything better that could give me headphone out and remote, but having thought about it and seen that the Slagle has 2 outputs it would seem the best option for my needs would be too add a headphone amp to the spare output on the Slagle and forego the remote.
The EWA Q20-P would no doubt be ideal but I don't buy new nowadays and would rather look for value in used items, not that I think that the Q20 is poor value, it's very good, I've not heard it at home yet.
I'll have a hunt around for a headphone amp to try out and see if that's the way to go.
