Page 7 of 10 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 92
Thread: Latest Project - EAR 834P CLONE
  1. #61
    Some options that I wont be adding to the Clone.
    A SUT.
    An MC option.
    Dual volume knobs for L+R channels.
    No two box version
    There will be some monumental amounts of tube rolling and maybe a little bit of cash spent on some boutique parts if I get chance to have a look around hifi collective.
    PRE
  2. #62
    Here’s my build thread over on LH http://www.lencoheaven.net/forum/ind...?topic=23945.0
    David.
  3. #63
    Thanks. I will start at some point going through these threads.
    PRE
  4. #64
    A little more progress. I managed to get a quick hour away from child to populate the PCB.
    Transformer has been orderded. I've managed to find a load of solid core silver for the internal wiring. Just awaiting the case to arrive. Also having a little splurge at hifi collective!
    PRE
  5. #65
    I've been chipping away at this slowly whilst doing several other projects. So, I've optimised the leg length of several caps and resistors. My transformer has arrived so now its time for a case. Now this is where you can spend a chunk of cash on a nice looking case or you can think laterally. I initially found an unpopulated case costing £85 from China but it needed a shed load of drilling and other bits and pieces doing. So, enter cash generators! I've seen a few old amps for sale but with a killer case and here's the kicker the IEC, on/off switch are already installed, the RCA and various power holes are already drilled and I can get the case as soon as I hand my cash over and it's cheaper than £85. Its a win/win/win situation I get a cheap case with sexy grab handles, several of the components are already installed so they cost nothing and I dont have to waste time or money modding the case too much. Cabling has also been sorted out and its a mixture of solid 2mm silver or copper, this cost NOTHING!
    I have had to spend some money on this build! I bought x3 of these little beauties. General Electric 5751 JAN GE NOS, miltary spec with very low microphony, these cost £<90 which is a lot cheaper than HotRoxUK who wanted £180 for the same piece of kit
    I've also splurged and bought some valve dampening rings and being a tight arse I managed to save some money here as well. I needed 9 in total but I would have had to buy as these are usually sold in pairs. The cheapest price I could find for x2 was £2.99 meaning 10 would have cost £15 I managed to get 9 delivered from China for £9. I'm currently on the look out for a female IEC and I'd like a pure copper version from Furutech and I would also like some solid copper female RCA's or better still some Pure silver jobbies. My final bargain came from AOS and this is the power lead which will power the new clone. This is a lovely power cable with high purity OPCC copper from Furutech its a tripped shielded mains lead and it also has silver plated IEC and plug, total should have been over £100, I managed to get this baby for £65.
    I'm still hunting for bits and pieces and I'm in now rush to finish this project as I already have one 834 clone up and running! So stay tuned.....
    PRE
  6. #66
    Bit more progress tonight. Finally decided upon the case I'm going to using and yes it's got grab handles .
    Furutech high purity copper IEC.
    Just a few odds and sods and then I should be able to start assembly.
    PRE
  7. #67
    Hmmmm very near to starting to finish this project
    More components
    The box finally arrives and is assembled (GRAB HANDLES)!
    A quick mock-up.
    More to follow.
    PRE
  8. #68
    I'm Tony.
    Nice, I see you've gone with the Russian PIO caps.
    I used these in my Yaqin MC100B to replace the cheap Chinese Dragon Coupling Caps.
    They sound really nice in my amp.
    I've been tempted to just buy one of those Douk 834P clones (MC) for a looksie but can't help but be skeptical as to what they have used as a SUT.
    Anyway, looking forward to hearing your report on the finished item.
    VPI Scout 1.1, Hana ML, Vanderveen MC10 SUT, WAD Phono3, Rpi3B+/Digione Signature, Xiang Sheng DAC-01, WAD KiT6550 and Reiver Edingdale SR
  9. #69
    Quote Originally Posted by Intenso View Post
    They haven't. You use your own.
    PRE
  10. #70
    I'm Tony.
    I was referring to the pre-built 834P that Douk sell on ebay.
    The SUT are housed in what seems like everyday copper plumbing pipe!
