Page 2 of 10 FirstFirst 1234 ... LastLast
Results 11 to 20 of 92
Thread: Latest Project - EAR 834P CLONE
    It's a great stage for the money the basic kit from DOUK is very good but you can get much better results by following the advice here http://www.lencoheaven.net/forum/ind...?topic=26658.0 and in the near future there should also be an uprated PSU currently known as Roberts PSU.
    I've built a two box version following the advice with carefully matched components and for about £250. With all the advice out there even for an electronics novice providing your careful it's certainly within most HiFi fans capacity to build one of these stages. The main thing hampering the original EAR 834 was the quality of the components used and the MC SUT's...well if you change those to 1% matched components and get some decent SUT's( if required for MC carts) and you've got a pocket rocket.
    Most of the changes proposed were suggested by a guy called Thorsten when Romy The Cat was building his ultimate reference 834 stage....so if it's good enough for extreme Audiophiles like Romy it's good enough for me
    David.
    I'm already a member of LH and I'm following the threads with great excitement!
    PRE
    I'm Jez.
    Sorry to p*ss on your parade Andy but IMO the 834 will never make 'reference' standard.
    Its biggest problem is that it employs feedback equalisation, that gives a 'compressed' sound.
    Just saying
    Whilst I agree that the 834 will never make a reference phono stage I disagree with the reason. IMO a feedback phono stage can sound just as good as a no feedback one. A feedback stage has several technical advantages over a no feedback one also. It's all down to how it's implemented
    I'll go with that, it's a different set of compromises, so I will just say I prefer the passive rather than feedback EQ sound.
    I'm Jez.
    I wouldn't even say there is a particular passive eq sound or feedback eq sound! Maybe a series feedback V shunt feedback difference though yes.
    A feedback eq stage will generally have much greater dynamic range than a passive version, technically that is, I'm not referring to subjective effects.
    I'm Deleted.
    I am interested to know, does the paradise use feedback equalisation?
    No, it doesn't - but Andy is looking for a MM stage and the Paradise is strictly MC only.
    P.S. You know you can turn off the 'sent from my phone' signature.
    Account Deleted
    Bigman80 Guest
    That's very interesting. I may try and build a paradise stage one day. I'd like to hear what it can do.....and I did know. Thanks 😉
    I'm Deleted.
    Default Latest Project - EAR 834P CLONE
    Bear in mind the circuit boards are becoming very hard to find and there is a lot of component sourcing and matching to do.
    Account Deleted
    Bigman80 Guest
    Bear in mind the circuit boards are becoming very hard to find and there is a lot if component sourcing and matching to do.
    Oh, maybe I'll start a bit simpler lol
    I'm Jez.
    I'd consider designing a "paradise on the cheap" if there was the demand... but there isn't....
