Results 1 to 7 of 7
Thread: Hi from Manchester
    I'm Wayne.
    Default Hi from Manchester
    Hi all just joined and completely new to this new world of sound systems. I want to start small and take it from there.
    I was wondering if these components would work together and woul I need to order any seperate cables or anything else just to listen to my old vinyl lps.
    marantz pm 5005 amp or a onkyo a9010
    project primary turntable
    AKG k550 headphones
    Any help or suggestions greatly appreciated.
    I'm Andy.
    Hi Stan
    Welcome to the forum.
    I am not familiar with the amps and kit you have listed, but someone will be along soon who is.
    Enjoy your time here.
    Analogue
    401 / PU7 / AT33ev
    Digital
    Innuos Zen Mini Mk 3
    Topping D50s
    Caiman Seg & Dorado
    Cambridge CXC
    Amps
    Tron Seven Linestage
    Speakers
    Tannoy GRF Memory.
    Tannoy ST100.
    Hello Wayne. Welcome to AOS.
    I'm not familiar with the equipment models you are interested in either unfortunately.
    If you start a thread in the Blank Canvas section, outlining your ideas and needs, I'm sure you'll get plenty of opinions.
    There's much second hand and vintage gear well worth considering.
    Enjoy the forum,
    Geoff.
    I'm Andy.
    Wayne if your in Manchester there are lots of forum members local to you.
    Before committing to buying anything, try and hear a few systems. Loads of us have more than one system , one of which is often based around budget components, which might help you find what your looking for without risking buying stuff unheard.
    Andy
    Analogue
    401 / PU7 / AT33ev
    Digital
    Topping D50s
    Caiman Seg & Dorado
    Cambridge CXC
    Amps
    Speakers
    Tannoy GRF Memory.
    Tannoy ST100.
    I'm Wayne.
    Thanks for the replies guys. Ill have a look through the forums, seems there is a lot moreto all this than i thought lol
    Quote Originally Posted by Stan66 View Post
    Some of us have been at this game for forty years or more Wayne and are still learning.
    Oh. And some superb sounding equipment can be over forty years years old as well. Believe it or not.
    Welcome to AoS Wayne,
    Don't worry - we all had to start out knowing very little.
    Although I'm not familiar with any of the gear you mention, I see no reason why it should not work together.
    If the Project TT comes with a lead fitted, then just plug that into the input on the back of the amp marked "Disc", or "Phono". If not, then buy a pair of 1m long interconnects terminated with RCA phono plugs and use that.
    The headphones can be plugged into the headphone jack socket of the amp; assuming it has one. Ideally you need to fix a 10W rated 8
    Ohm resistors across each of the loudspeaker outputs on the back of the amp.
    Regards
