Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Garrard 401 now completed! ... and most of the bits for it off the forum :)
    montesquieu Guest
    Default Garrard 401 now completed! ... and most of the bits for it off the forum :)
    Got a Garrard 401 motor unit from Ali Tait a few weeks back .. finally as of today it's now in its plinth
    Arm is an AT-1010 sourced from Jerry (originally from phonomac I believe), with an AT-7V cartridge (superb low compliance MM) from mad-moon. Fitted in the original heavy AT headshell this is an utterly perfect match for this arm - synergy indeed. Tonearm cable is one I had kicking around from Audio Origami. The plinth came from Austria/eBay, very modestly priced for the quality.
    Motor unit needs a bit of TLC, it lost some bearing oil on the way down from the Auld Country, I've topped it up but will give it all a good clean out when a new gasket arrives in a day or so - I think it needs a good bit of running, the wheel is a bit noisy/uneven but I suspect that will settle down with a bit of play as the rubber seems OK (not hardened or anything) - maybe just needs to spin for a while after a period of not being used.
    The sound has been getting better and better even in the couple of hours of play that it's had - reminds me of everything I like about Garrards, full in the bass, very musical, enjoyable. The big surprise has been the arm. It never seemed that happy on the Technics it arrived on but it's just right here, it's a really lovely, high quality thing, beautifully made and engineered. A real sleeper I think - at 16g mass it must have been a bit of an anomaly in its era, coming out just as super-lightweight arms and high compliance cartridges were all the rage, it must have been hard at the time to partner it optimally as all the big name 'favourites' were high compliance, this needs something in the medium-low compliance area.
    Garrard bolts came from eBay, and from the local hardware store a hole cutter to do the armboard, and a tubular spanner to do up the nuts ... I don't know if this minimal bit of effort really qualifies it as a DIY project as all I've done is assemble it, wire it up, and set it up. Nice bit of fun though and an interesting contrast to the TD124 MkII.
    Bigman80 Guest
    That look the business, mate. Im really taken with that. Well done!
    I'm inthescottishmafia.
    Nice Tom, glad it's doing the business.
    Hunter S Thompson
    montesquieu Guest
    Spoke too soon. Left it running when I went out to the supermarket. Not running when I got back Now to diagnose .... didn't seem to have overheated .... wiring looks ok ... bit puzzled actually.
    I'm sorted.
    Check the speed adjustment magnet isn't fouling the flywheel, that's what happened with mine.
    montesquieu Guest
    Unfortuantely no .... seems free enough.. also just been through all the wiring but all seems fine. Nothing burnt either that I can see. It's a mystery!
    Bigman80 Guest
    Fuse? I spent hours testing mine ages ago and it was the fuse lol
    montesquieu Guest
    I tried a different mains cable already ... is there an onboard fuse somewhere?
    montesquieu Guest
    Genius - yes it was a fuse - there was one fitted in the plinth IEC socket. Huge thanks.
    Why it blew I don't know but at least I can watch out for any issues now.
    Cheers Oliver!
    Good to hear Tom, would have been surprised if there was a problem with the unit, it's never given me any problems.
    Hunter S Thompson
