Results 1 to 10 of 11
Thread: Free TDK and Magnex Tape
    I'm Bob.
    Default Free TDK and Magnex Tape
    I have been given (FOC) 3 reels of TDK Audua L1800 tape. Also, a 10.5" reel of tape in a Magnex box (so it may, or may not be, Magnex - but the box looks like a premium product).
    The TDK is declared new, and from it's visual state (still plastic wrapped with unwrinkled leaders) could well be.
    The Magnex, if that's what it is, may have been used but I haven't put any these tapes near my player yet.
    Are they known to suffer from any of the declared SSS issues and likely to gum up my tape path, or are they worth trying out? I've not been able to find too much on Google about them.
    Bob
    Source: Orbe SE / SME IV / Cadenza Bronze
    Source: WD NAS / Cyrus Stream X2 / Chord DAVE
    Source: Oppo UDP-205 (CD/DVD-A/SACD)
    Amplification: Icon Audio PS 3 Sig Phono + Audio Research LS27 + Musical Fidelity A5cr Power Amp
    Loudspeakers: ProAc Response D28
    Cables/stands: Mark Grant G1500HD + Linn K20 + Cat 5e
    Other bits: Okki Nokki keeping things clean
    Don't know about those tapes Bob but when I put some old unused Pyral on my Grundig it shed oxide for the first two run throughs.
    I managed a good recording on the third pass.
    Dont know about the Magnex but the TDK Audua will be fine and is good tape
    Alan
    I'm Bob.
    This shedding oxide business: is it just a simple, normal clean with isopropyl alcohol to remove it? It's nothing more sinister is it?
    Quote Originally Posted by 337alant View Post
    Alan
    I might just have a go with the TDK as I remember it as a well respected name from the days of cassette. Magnex I've never heard of and can only find references to Magnex Cassette tape on Google. So this one may stay in the box for a while.
    Thanks both.
    Yes just clean the tape path as you would normally.
    Perhaps the good thing is that the oxide is easily visible.
    I'm Bob.
    That'll be OK then, the hammer and chisel can stay in the drawer...........
    load the tape up and do not press play, press FF, note if there is a gradual slow down ?, half way through press stop and check the the tape stand off guides for a brown oxide deposit
    Then REW back to "0" and check again ?
    If there is nothing on the guides the tape is good to go
    If there is a build up of oxide and a noticeable slow down on FF / REW bin the tape and keep the reel if its metal
    Alan
    I'm Bob.
    So it sheds as quickly as that then?
    The things I'm picking up that seem obvious but aren't until you know. I'll have a go before I get serious with any of it.
    Thanks Alan.
    Quote Originally Posted by bob4333 View Post
    Thanks Alan.
    Bob Yes if its sticky it will start shedding straight away
    Its easy to get it off the stand off guides with isopropyl alcohol but more difficult to get it off your heads so don't test in play mode
    This is what it looks like
    sticky2 by Alan Towell, on Flickr
    sticky8 by Alan Towell, on Flickr
    Cleaned
    sticky9 by Alan Towell, on Flickr
    Alan
    I'm Bob.
    Thanks Alan. I don't know what I thought it might have looked like, but it certainly wasn't that! Something to be avoided.
