Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Thorens TD 160
    I'm Dan.
    Default Thorens TD 160
    Hi Guys
    Well this arrived today along with another FM4
    Seems to be running OK on 33 but slipping on 45 the belt seems a little slack so im guessing its time to order a new one? - does anyone have one i here i could use to test to see if it is the belt as dont really want to buy a new one if the fault is elsewhere - the spindle is clean and the motor is fine too
    Boxed too needs a good clean very presentable pictures to follow the guy has more goodies too from a clearance in Christchurch i made him an offer he took it
    Receiver
    1980 Yamaha CR 2020
    CD Transport & DAC & PSU
    Loudspeakers
    Rogers LS7
    Secondary
    Sony HCD SD1 Receiver with built in CD Player
    Mordaunt Short MS10
    Sony SA CS1 Subwoofer
    Piccies?
    I'm stuart.
    If it's just the belt slipping making the speed inconsistent then it's the belt that is stretched. If it's the belt slipping off the pully (or failing to ride up on to the large part of the pully) it may still be the belt or the motor azimuth. If it's the belt slipping off the pully only when you stop the platter it's either the clutch or the azimuth ... well that's what I've found on the many 160's I've worked on.
    Great advice on Thorens here, including belt sizes: https://www.vinylengine.com/turntabl...pic.php?t=3095
    Bigman80 Guest
    The Thakker branded belts are usually what people recommend. Ive been looking at 160's for a while. I still regret never buying Grants.
    I'm Loz.
    I have a spare Thakker you'd be welcome to borrow if you'd like to test it Dan, but if you intend to keep hold, it might be worth putting the postage costs into picking up a new belt anyway.
    I'm Dan.
    Piccies?
    When i get in from work...
    Receiver
    1980 Yamaha CR 2020
    Loudspeakers
    Rogers LS7
    Secondary
    Mordaunt Short MS10
    I'm Dan.
    Quote Originally Posted by killie99 View Post
    Thank you..
    Receiver
    1980 Yamaha CR 2020
    Loudspeakers
    Rogers LS7
    Secondary
    Mordaunt Short MS10
    I'm Dan.
    Gorgeous looking thing this one need a clean but otherwise sound...
    Receiver
    1980 Yamaha CR 2020
    Loudspeakers
    Rogers LS7
    Secondary
    Mordaunt Short MS10
    I'm Dan.
    Quote Originally Posted by HackneyRF View Post
    PM incoming...
    Receiver
    1980 Yamaha CR 2020
    Loudspeakers
    Rogers LS7
    Secondary
    Mordaunt Short MS10
    I'm Dan.
    Pictures - Clean up not yet done the lid is present but a little worse for ware.. still usable...
    Receiver
    1980 Yamaha CR 2020
    Loudspeakers
    Rogers LS7
    Secondary
    Mordaunt Short MS10
