Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 46
Thread: Pye Mozart HF10 stereo pair
    I'm Kai.
    AFAIK JJ EL34 quality is fine these days, at least a well respected Finnish vendor seems happy about selling them, which apparently isn't the case with JJ KT77 which they still don't recommend because of quality control issues, though I recall reading somewhere the KT77 have also gotten better. They also offer a "hifi graded" version of the JJ EL34, which they have ran in and tested extensively, apparently about 5-10% of product they get their hands on meets their criteria of specs. Adds 10 euros to the price per valve, so a pair would run about 50 euros, but they do throw in an extended (6 months) warranty, so might as well go with that. Haven't yet put in the order though and also noticed a NOS pair of Svetlana EL34 wouldn't cost that much more, so wondering if that would be a better value for money.
    I'm Jez.
    Quote Originally Posted by helma View Post
    I'd take Svetlana ("winged C") over JJ all day long At the time when I was getting loads of faulty JJ valves, most valve suppliers in UK were strongly recommending them! Call me cynical... but this makes me think the suppliers were getting a good mark up on them... I do hope that QA has indeed improved since then (about 10 years ago).
    Just an aside but it amazes me that Mullard are so sought after over Brimar, Mazda etc... All of the "BVA" British and European valves from the golden age were of good quality and I sometimes find Brimar to be better than Mullard!
    I'm mick.
    Try some Russian 6p3s-e,[gold grid] a lot cheaper than n.o.s Mullard .I have used them and can recommend them,although they are not quite the bargain they used to be.I agree with Jez about Brimar and Mazda rivalling Mullard,at this moment I have a set of Mazda's in my amp which I prefer to Mullard's I had previously. Mick
    Nothin' I do don't seem to work ,it only seems to make matters worse!. Jagger/Richards
    I'm Jez.
    Quote Originally Posted by mik_rik View Post
    I wouldn't recommend this! It's a 6L6 near equivalent (lower max ratings than 6L6... bit of a weedy version) and not entirely compatible with EL34. It's a beam tetrode whilst the EL34 is a pentode for a start... It should work but requires different bias and screen grid voltages for proper operation. How it would react to the cathode windings in the Pye is any ones guess!
    I'm Alex.
    I'm no expert on valves, but I thought Brimmar and Mazda were often Mullards in disguise.
    Spendorman
    I'm mick.
    A helluva lot of guitar and audio people use the 6p3s-e [not 6p3s which is a totally different valve] built for Russian military and are not "weedy" in their experience.Nothing wrong with trying them after reading other peoples experience .A kt66 is a kinkless tetrode and was GEC'S way around 6l6 patents and is different again ,and people sub 5881 6l6 ,el34 etc in amps up to Quad11 for them.Different construction does not mean they are not able to be used .I can only talk from experience and have used 6p3s-e in a Radford STA 15 ,no red plating ,have took said amp to NEBO's , no issues that anyone heard.I would definately trust them a lot more than other el34's on sale from some ,even reputable vendors.YMMV Mick
    I'm mick.
    Quote Originally Posted by spendorman View Post
    Mullards are recognisable by a code etched onto the glass[usually starting with the letter b denoting Blackburn plant,a double seam on top ,and a hole in the locating spigot.Towards the end of valve production,there was quite a bit of cross buying going on but I have no Brimar or Mazda Mullard made,including Ecc and Ef types. Mick
    I'm Jez.
    I haven't heard your Radford but other than that I strongly disagree with everything you said I'm afraid...
    I'm Jez.
    As Mick said, towards the later period all sorts of things were marked as being a different make... there were even things like Tesla's etc marked Mullard...
    I'm mick.
    At present ,the GZ34 rectifier valve I am using is branded Zaerix but is Mullard [I would not use anything else,to me more important than the pre and power o/p valves]Goes to show you don't always know who made what.I would use any of the old makes before I would risk losing a mains t/x or an o/p t/x to some of the modern ,cheap Chinese valves. Again ymmv but just my 2pennorth Mick
