There seems to be some settings missing to allow you to do this! Anyone?
I'm Nobody.
Andre... in the UserCP, under Edit Signature. You upload the picture you want or add a link to it in the appropriate box, then hit the 'Insert Signature Picture' link. This adds it to your sig.
Make sure its not too big so it doesn't get in the way of the beautiful clean lines of the general forum design
Hope this helps!
I'm Nobody.
Hi Nick
Yes thats how i've done it before on other V Bulletin boards, but that option seems to be missing on mine hence why i was asking if the settings were missing!!
Weird. They're there for me. I'll check the settings for the 'Registered Members' Usergroup and see what gives
I'm Nobody.
cheers nick i only want to tell the world prog rocks
I'm Nobody.
Nick this is the permissions i have at the bottom of the Signature page, clearly says no at the bottom.
Allow Basic BB Code Yes
Allow Color BB Code Yes
Allow Size BB Code Yes
Allow Font BB Code Yes
Allow Alignment BB Code Yes
Allow List BB Code Yes
Allow Link BB Code Yes
Allow HTML No Allow Image BB Code No
Allow Code BB Code Yes
Allow PHP BB Code Yes
Allow HTML BB Code Yes
Allow Quote BB Code Yes
Allow Smilies Yes
Can Upload Images for Signature No
Can Upload Animated GIF for Signature No
Yep... you're right. I am seeking consensus from the rest of the Management Team regarding changing the current policy! I want to make sure it wasn't switched off for a good reason before I make any changes! Hang in there dude!
Hi Nick,
Feel free to change it to help Andre out
Use the smaller of the two options.
Consider it done. In fact. It is done.
There's a 500w x 50h contraint on image size, and static images only
The change is universal for all members with 3 or more posts. Fill yer boots!
