Results 1 to 9 of 9
Thread: Paint (or veneer) job help
    I'm Josie.
    Default Paint (or veneer) job help
    Hi all.
    I have a plinth for my Thorens and would like to know if anyone here (or could recommend someone) who could respray it in piano (high gloss) black?
    ...Or, to maybe veneer it and lacquer it to a piano gloss finish?
    Many thanks
    Jo
    Preamplifier: Croft Epoch Elite - Dual external PSU & Upgrades
    Amplifier: Tube Distinctions Copper Amp No. 5 using KT150's
    Digital: Raspberry Pi & ALLO Piano DAC & KALI - IQAudio DAC with SBooster Linear BOBW PSU & Trio DP700 CDP
    Turntable: Thorens TD124 MkII - Schopper refurbished
    Tonearm: SME 3009 S2 None Improved - Audio Origami modified
    Cartridge: Ortofon SPU GT
    Speakers: 15" Tannoy Monitor Golds in Lockwood Majors with Tannoyista Spec 3 crossovers
    Cables/Mains: Mark Grant Black Series mains cables & 6-Way power bar
    Cables/IC's: Mark Grant HDX1 Pure Copper + Custom made Silver/Gold interconnects
    Mains Other: Tube Distinctions/Mark Grant 'The Power Works' Digital noise mains power filter TD2414-MG - Nick Gorham DC Blocker unit constructed by Mark Grant
    Just be aware that a "piano black" finish is not an easy finish to do and could be eye-wateringly expensive.
    Depends but a respray and lacquer would probably be a lot easier and cheaper. PB is really difficult outwith experts with the right equ
    Grant ....
    DENON DV2900 - TWIN PRO MONOBLOCK AMPLIFIERS - XIANG SHENG DAC\PRE\HEADPHONE AMP - AUDIO TECHNICA ATH-MSR7 & OPPO PM-3 PLANAR HEADPHONES - WIN10 JRIVER23, SPOTIFY PREMIUM - SMSL M6 MINIDAC - FULL RANGE TWIN TELEFUNKEN's - Q ACOUSTIC BT3 actives - CANTON SUB - MAINS REGENERATED AND FILTERED.
    I'm Paul.
    How about a vinyl wrap, like on a car ??
    Try a signage place - it would be a heck of a lot cheaper and wouldn't take very long.
    Linn Sondek LP12, Ittok, A&R P77 > Musical Fidelity XLPS v3 Phono Stage
    Sony CDP-XE520 CD Player > SMSL Sanskrit DAC
    Pure DAB tuner
    Tisbury Mk.1 pre-amp > 2 x Meridian 205 monoblock power amps > Rega Jura Mk.2 speakers
    Grado SR80 headphones
    www.paulridgeblog.com
    I'm Russell.
    So how complicated is this Plinth? Could you just make a new one from a quality block of wood?
    I'm Josie.
    Sorry for the delay with this... Lol thanks chaps. Not sure what to do apart from find someone local who could do it maybe?
    Sent from my 9001X using Tapatalk
    I'm Brian.
    Take it down to a car resprayer and ask them if they can do it Josie .
    Regards
    Brian
    Korus Computer Audio music server .
    DAC 3 French DAC
    Amplifier : Rega Brio R
    Speakers : Tannoy 637
    Speaker cables : Chord Epic Twin
    I'm Mark.
    Something to bear in mind is the possible strata of the wood (assuming it is wood) used to build up the plinth. If the plinth is one huge block it will be easier to obtain a good finish: If it comprises several laminated layers I think a specialist would be best doing the piano black finish. If others, who are not especially adept at the furniture end of the market, handle the work - it may look good initially but it may subsequently suffer from splitting the paint along the lines of lamination.
    My plinth comprises three layers and after reading up on the piano black finish I copped out and went for a 60s 'rexine' style trim. It was a pilot after all, but several years later I'm still living with it.
    One thought is that there must be a number of highly specialised piano restorers across the country and if they are 'old school' they may just have a proper finisher who knows how to do this sort of work.
    We were flooded in late 2015 and a neighbour had a family heirloom piano which they had taken to such a specialist for full restoration, rather than settle for the cash equivalent. Theirs was a veneered rather than black piano but it was still a marvellous piece of work when it came back.
    Maybe worth a google ??
    There's a fantastic refinisher in Chester if that helps.
    Main system: Sony TTS8000; SME IV; Audio Technica Art1; Nakamichi CA7 pre-amp; Nakamichi PA7 Power amp; Lentek integrated; SBT; Technics sh-x1000 DAC; Yamaha NS1000M.
    System 2 - SBT; Denon PMA850 integrated; JBL 4312B control monitors.
    System 3 - Taken over by my son! Chromecast; Beresford Caiman II; Klark Teknik Jade 1 active studio monitors.
