Originally Posted by
Shuggie
My mate Steve (Snoopdog) has just done this in his house, so hopefully he'll chip in with some thoughts.
My meter and incoming supply is situated in a cupboard under the stairs and is only a short journey through the wall into my now, dedicated, music room.
My specification was only for a single socket supply in the listening room, situated by the hi fi equipment stand. I favoured a dual radial supply from a dedicated consumer unit, rather than a spur and this is what I ended up with.
The components used were a MEM AP4 consumer unit fitted with a single MEM MBH132 B32A MCB with MR30 field fit RCBO kit. There is of course room for three additional MCB/RCBO's if I wished to expand the number of dedicated cale feeds in the future. Anyone considering more spurs/dual radials, should specify a six way or larger consumer unit.
Instead of heavy guage T&E cable I went with an RS Components twin shielded cable with 20amp rating (identical to that used by MusicWorks for their ReCoil mains power cord. Two identical 1.8M runs originate at the MEM consumer unit and terminate at a rather expensive outlet called 'The Lens' designed by Paul Chand and incorporating high precision ceramic isolation bearings, a floating alluminium alloy front plate and solid PTFE middle and rear section. The idea being to attempt to isolate the socket outlet from vibrations in the wall. The RS cable shield is connected to earth at the CU end only, so acts as a drain rather than a shielded cable.
If anyone is interested I will post some pictures of the installation.
The result has been very satisfying with much greater detail retrieval and noise reduction compared to the house ring main.
I use a Vertex Elbrus mains balanced PSU to supply my hi fi with power from the single wall outlet.
Steve
Steve.
My System:- dCS Vivaldi Transport + dCS Vivaldi Apex DAC + dCS Vivaldi Master Word Clock + dCS Vivaldi Upsampler Plus, Aurender N20 Music Server/Streamer, TW Raven One tt/Graham Phantom II/Transfiguration Orpheus L & Audio Technica ART20 mc's, Whest Titan Pro, D'Agostino Momentum HD pre/S250 MxV power amp, TAD CR-1 MKII loudspeakers, REL Gibraltar G2 subs, Coherent Systems BD Mains, interconnects & speaker cables, Sablon Audo EVO USB cable, Tellurium Q Ultra Silver power cords, Ziro Disclosure & Vertex Roraima Hi-Rez power cords + Furutech FI connectors, Stillpoints ESS racks/component stands, Vertex Aletheia PSU2 balanced power supply, Coherent Systems RTZ3 ground box + CR/BD cables, Acoustica Applicata DaaD room treatment, Mutec Ref10 SE-120.
