Results 21 to 30 of 34
Thread: Sibilance in general -- what is the most likely cause?
  1. #21
    I'm Tim.
    Care to explain?
    Dirt wil add noise but no distortion. Sibilance is a distortion of a recorded sound either at the recording take or in the process of the "carving" of the master template or in the "plastic" material used to press the record. And off course, as said before by a faulty set-up of your cartridge and/or tonearm.
    - Cart Denon DL-102 in bakelite Ortofon SPU 'G' type headshell
    - TA SME 3009 'Improved' converted in heavy mass with detachable headshell
    - TT Thorens TD 145 totally tweaked driven by an 'Eagle & RoadRunner' PSU & tachometer combo
    - Matts top to bottom: leather, cork, felt & 12" vinyl
    - Pre-amp 'Modulis' Isem
    - Amp 'Exampli' Etalon 2x40W
    - Speakers 2 ways 12" Leak 'Sandwich' 15 OHMS
  2. #22
    Sibilance can be caused by mistracking stylus or too little VTF. Stylus profile can also be an issue. Occasionally recordings can be prone to sibilance if vocals are recorded poorly.
  3. #23
    I'm George.
    Sorry to be a late comer to this thread, but I've just joined.
    Personal experience has shown that VTA and correct bias are particularly important to reducing/eliminating sibilance. Of course the record deck must be perfectly level too. Having said this, there is absolutely no guarantee that every cartridge, even if brand new well set-up, would ever be able to track sibilance well. Relevant points are the tip mass of the stylus, cantilever compliance and tip profile (Shibata tips are very good at tracking high frequencies). As has already been mentioned, cartridge/arm mass compatibility is very important too. If the cartridge isn't brilliant at tracking sibilance, it doesn't mean it's a bad cartridge – it's just not one of it strengths.
    Some records are cut with too much extreme HF making sibilance virtually untrackable by anything – especially if the record itself is a fraction off centre (which they often are), and the arm is swinging slightly.The cutting engineer should filter off extreme quantities of HF at the time of mastering to ensure the record can be played cleanly on the majority of decks.This is especially so at the end of side when the stylus is traveling at its slowest making tracking HF more difficult.
    I hope this is of some use. George.
    Main system: Sony Biotracer PS-B80 record deck. Kondo IO-M cart. ASR Basis Exclusive phono stage. Convergent Audio Technology SL3 valve monoblocks. Audio Note (Japanese Audio Note now known as Kondo) M7 Custom pre-amplifier. Wilson Sophia 2's on Townshend isolation platforms. Siltech G6 “Emperor” speaker cables. Interconnects: Audio Note AN-V. Kemp mains conditioner and mains cables.
  4. #24
    I'm Ken.
    Sibilance is not just restricted to a vinyl source.
    Don't think the OP has been back to say whether it is just on his TT.
    Ken
    http://www.jkwynn.co.uk/
    DIY Technics/ProJect based Turntable + Terminator linear tracker + AT 33PTG II / AQVOX Phono 2 CI / Pro-Ject Pre Box RS / ESP Active X-Over / Nakamichi AVP1 Power / Modified semi-active Yamaha NS1000M Speakers / Stello CDT100 Transport / NAD M51 DAC.
  5. #25
    I'm kickinbacklistenintotchoons.
    Any TT based sibilance I've had and subsequently cured has always been down to either VTA (usually needs to be more 'tail down') or VTF (usually needs to be the odd 0.1 or 0.2 gm heavier).
    My stuff -
    Analogue: Technics SL-7 / EPC-P202C
    For when there's no Analogue: Doge 6 CDP
    To discover loads of new music: Spotify via Laptop into Xiang Sheng DAC-01A
    Make music louder: Quad 34 pre, 200W/side Class D (IRS2092) power
    Music boxes: Heco Celan 300
    Cleaning duties: Okki Nokki 2
    Y'know, sometimes, Satan, come as a man of peace.
  6. #26
    I'm AMusicFanNotAnAudiophile.
    Quote Originally Posted by tlscapital View Post
    No it's not.
    Sibilance occurs in real life.
    Chris
    Once we've made sense of our world, we wanna go fuck up everybody else's because his or her truth doesn't match mine. But this is the problem. Truth is individual calculation. Which means because we all have different perspectives, there isn't one singular truth, is there?
  7. #27
    I'm Peter.
    I fear not my friend...... nothing to to do with real life !
    It's to do with set up
    VTA is really important, as is is all other crucial adjustments.
  8. #28
    Quote Originally Posted by Boyse6748 View Post
    Bollocks!
    I heard sibilance just the other day.
    Funnily enough it was my friend, saying the word "sibilance", and I noticed that it was, funnily enough, very sibilant.
    It's got fuck all to do with anything else.
    It's often picked up by the microphone when summat's being recorded ....
    Chris
  9. #29
    Makessss sssenssse to me.
  10. #30
    Poor set up or other issues could introduce it when it is not there on the recording though? Obviously the effect is not happening for the same reason but it might be hard for a listener to distinguish between the two.
    Martin
    Sony X505ES CD Player * NVA P90SA passive pre / Krell KSA50S Power amp * JM Lab Electra 926 loudspeakers *
    ''I like to be objective about my subjectivity.''
    - Geoff 'Walpurgis'
