Results 1 to 10 of 12
Thread: help please
    I'm al.
    Default help please
    how would you rate this MUSICAL FIDELITY V90-DAC against BUSHMASTER 2 AND THE CAIMAN 2,a detailed responce would be nice
    cheers
    linn and naim man here
    I'm Neil.
    I find Musical Fidelity digital gear rather bright as in false detail, the Beresford new DACs not as bright. I would choose the Caiman 2 Short response but hope it helps.
    Mana Acoustics Racks / Bright Star IsoNodes Decoupling >> Custom Silent Media Server >> Halide Bridge USB (with AQVOX USB power) >> Pedja Rogic's Audial Model S DAC + Pioneer PL-71 turntable / Vista Audio phono-1 mk II / Denon PCL-5 headshell / Reson Reca >> LFD DLS >> LFD PA2M (SE) >> Royd RR3s.
    I'm al.
    Default hi
    cheers m8,ive got a bm2,and been of offered a caiman 2 for £100 with chip upgrade and i was offered a mus fid as well but i dont know if the caiman 2 is worth it,its something to play with
    thanx
    Al
    I'm al.
    what do you think of the mana stands m8
    I'm Ian.
    If its any help I use a Musical Fidelity X DAC which is a big improvement on the Marantz built in jobbie. The bass is warmer and much more full and rich while the mid and treble are nice and clear but not harsh. The soundstage is wider and generally less clinical.
    My stuff; Toshiba SR-370/Mission 774 /Ortofon Quintet Black, Cambridge CXC CD transport/Musical Fidelity X DAC/Musical Fidelity X10v3 tube buffer, Musical Fidelity A3, Nakamichi CA-5E pre amp, Acoustic Solutions FM/DAB tuner, Mordaunt Short Signifer, Klotz MC5000/MS audio, NVA LS5
    I'm al.
    Default hi
    thanx for the info,IAN
    cheers
    Al
    I'm Craig.
    Caiman without doubt.
    Naim Mu-So
    Thatís all.
    Nothing else.
    I'm al.
    So is a second hand caiman 2 much better than a bm2 in what way and is it worth £100
    Cheers
    I'm al.
    Quote Originally Posted by al b back View Post
    Cheers
    Can someone give me there opinion is the second hand perfect condition caiman 2 with super chip worth £100 and is it a worth while upgrade over the bm2 and what would be in sound quality what extra would I expect to hear over the bm2
    I'm Neil.
    First off, I love how they look. Functional & clean.
    Secondly they are a bitch to set up properly, I get good success from sticking 10p coins at the angles to sit the glass on, and then moving the spikes up to meet them + final tuning: you are looking for a clean 'bonnng' sound with no rattle.
    Thirdly I think that they make things a bit more 'lively' and 'cohesive'.
    And finally: don't try to use one of their Sound Tables with a non-suspended turntable! Wall mount is better.
