Hi Everyone
To conclude feedback on my experiment I have found the best sound seems to be with the SDS mat (the right way up), and Herbie's way mat on top.
There seems to be a slight step in the spindle that stops the sds mat sitting completely flat against the platter - I guess the precise height of the platter will vary very slightly depending on the mating of the hole in the platter to the bearing spindle taper. If the sds mat is slightly dished, it means that it sits on the perimeter of the platter whereas it doesn't the other way up.
Anyway, i went through a full setup - alignment, tracking weight, vta and azimuth and it really is sounding good now. It's a very worthwhile improvement and everything now gels nicely where it sounded a little thin in the mids and bloated in the bass.
Thanks everyone for your advice.
Alex
Sent from my ONEPLUS A3003 using Tapatalk
Technics SL1210| Jelco SA-750| Benz Micro ACE SM MC| Squeezebox Touch/MCRU linear PSU | Cambridge Audio 851C | High Resolution Music Streamer II+ / Linestreamer+ | Raspberry Pi 2/IQ-Audio DAC+ / Max2Play | Conrad-Johnson ET3 Control Amplifier| Conrad-Johnson LP125sa KT120 Power Amplifier| Avalon NP Evo 2.0 Speakers| Cardas Audio Quadlink-5C Speaker Cables and Interconnects| Finite Elemente Pagode Signature E-14 equipment support
TV LG55B7 OLED
Oops, I meant mat, or 'platter mat'... :P
http://srm-tech.co.uk/epages/4c00892.../Products/APM1
I used tiny tiny blobs of blutack to fix to the technics platter & killed all ringing stone dead.
