Page 4 of 12 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 117
Thread: Yamaha ns1000m
  1. #31
    Bigman80 Guest
    Look good mate.
  2. #32
    I'm jamie.
    Thats an av amp...a big un too.. probably about 200£
    its got a phono stage too
    My System
    John Wood KT88 Amp.
    Paradise Phono Stage
    Sony TTS-8000 Turntable.
    PMAT-1010 MK6 Tonearm.
    Ortofon Cadenza Bronze
    Sony X555ES Cd Player
    Yamaha NS1000m Speakers
  3. #33
    So you did get a bit of a bargain in the end. Good news!
    The AV amp is from early nineties and so has no value as an AV amp nowadays, although it was an expensive one at the time. I'd say £100 tops, be very hard to shift it at any price I suspect.
    Still the Yammies are sound and that's what matters.
  4. #34
    I'm jamie.
    yes i suspected that mate due to lack of hdmi inputs. hmm now do i get into home cinema??
    My System
    John Wood KT88 Amp.
  5. #35
    You could have the Signifiers as the fronts and the Yams as the rears. That should move some air.
    Amp is not AC3/Dolby Digital so you will only have Prologic. Still would be fun though.
  6. #36
    A couple on the bay in nice nick.. asking £250 but unsold so less than that presumably. If its nice it will be a good standby amp to keep, especially if phono stage is decent and it might be
    Yep the whole worth of it, if any, will be in the 2 channel performance.
  8. #38
    I'm Deleted.
    Jamie, that's excellent news that the Yammies are in full working order. To get the best from them, like any good speaker, you need to work on the setup. Replace the spring clip terminals and feed them with the best amp and source you can afford - enjoy.
    Account Deleted
  9. #39
    I'm jamie.
    cheers,as you can imagine all thoughts of a tt psu are on the back burner
    im using a sony 700es amp at the moment,listening to some floyd they are sounding very good indeed,im sold!
    i have them about 125mm from the wall with about 15 degree toe in,all dials at zero. im hearing some very accurate bass.
    My System
    John Wood KT88 Amp.
  10. #40
    Incredible speakers. I have been listening to mine recently with the Lentek integrated. Bloody superb sounds.
    Main system: Sony TTS8000; AT1010; Audio Technica Art1; The Lentek; Cambridge 851n, Yamaha NS1000.
    System 2 - SBT; Technics SH-X1000 DAC; Denon PMA-850
