i received some decent binding posts today from the states.
My System
John Wood KT88 Amp.
Paradise Phono Stage
Sony TTS-8000 Turntable.
PMAT-1010 MK6 Tonearm.
Ortofon Cadenza Bronze
Sony X555ES Cd Player
Yamaha NS1000m Speakers
Nice!
I'm Eelco.
Last week installed the same posts, Also replaced the wires from post to XO with some decent cable.
Must say I didn't notice any change in sound. But the sturdier posts do give a peace of mind.
I still have the mid range at -3 dB and the highs at - 1.5 .
Sounds the best for me, also gives the straightest measurements.
Don't notice any problems with fase shift, as I believe Ynwan remarked.
Just check the binding posts are Brass. I got some similar looking items when I first got my Yammies. They felt a bit light, so I took a file to the end of the solder tab on the body part, they were white metal so I binned them. I use banana plugs exclusively on speaker leads, the solder, bodyless, Z type, so ended up getting some high quality banana sockets. Like these
http://www.jkwynn.co.uk/Yam_HTML/Yam_20.html
When Troels Grevensen did his crossover work on the NS-1000m he noticed that they were better with the mic set at mid range height rather than the usual Tweeter listening height. So maybe when tilting them back you are creating a similar effect at your listening position, the mid range being on axis with your ears.
Just a thought.
These are the ones I bought ken, I saw your thread so I didn’t buy from the guy in Japan doing them.
These ones came from the states.
https://rover.ebay.com/rover/0/0/0?m...2F112589548177
My System
John Wood KT88 Amp.
Hi Jamie - A lot of things on sale in the States are made in China, so it is still worth checking them.
If you look at the add, it just says Gold plated, but no mention of the substrate, which always makes me suspicious. The white metal ones I ended up with even had steel solder tags, Gold plated, but steel, a magnet soon confirmed that.
I re-used the plastic plates and replaced the posts with some Gold over Brass I got from a UK supplier and were a straight forward swap out. I used these for a while, prior to purchasing the Banana Sockets, which I now use everywhere posts would be found, including the back of Amps. They look good, take up less space and as they don't stick out, don't snap off when you bang into something, which I have done twice with posts.
Hope yours are right.
phew,a sigh of relief as mine are not magnetic.
My System
John Wood KT88 Amp.
I'm Deleted.
I’m making some new badges for mine in the style of the NS-5000
Account Deleted
