Page 1 of 12 12311 ... LastLast
Results 1 to 10 of 117
Thread: Yamaha ns1000m
    I'm jamie.
    Default Yamaha ns1000m
    These will be with me on Friday ,
    Hopefully all the drivers work lol.
    So what can I expect? Any tips on the mid/hf settings?
    My System/ Yamaha NS1000M speakers ,Pioneer PLC-590 turntable,Alphason HR-100S-MCS,Zeta tonearms,Denon 103M, 103SA Cartridge's,Denon HA-500 Head Amp, John Wood KT88 Valve Amp,Sony 700ES Amp,Sony X555ES CD Player, Nakamichi ca5 pre amp ,
    I'm Dan.
    Dont take the mid ranges apart if they dont work....they have beryllium in them they should all work though depends how they have been used in the past hopefully not thrashed/
    Pioneer SA 6300 Amplifier / Wharfedale Dovedale Speakers / Basic Cables
    Vinyl :
    Rega Planar 2 / RB250 / Ortofon OM Super 10 / VDH Oil Bearing Upgrade / Roksan R Mat
    AV Speakers
    Mordaunt Short - CS5
    I'm Mark.
    Personally I find they sound best with the trim pots set to 0 or close to. I think on mine the tweeter is a fraction lower than 0 and the mid is flat 0. I would start with this and then experiment. I did hear some not long ago with the mid turned to -3dB and whilst the owner claims it gave the flattest frequency response I find this impossible to believe as the mid sounded extremely recessed and almost like it had been disconnected! (It's easy to make a mistake measuring speakers).
    I'm not sure why you are being given the advice above. The drive units aren't intended to be dismantled and I'm sure you aren't intending to. However, unless you intend to grind the cones (both the mid and tweeter are pure beryllium) to a powder and inhale it you won't suffer beryllium poisoning.
    100% Analogue
    I'm Dan.
    Trying to help as Jamie has done tweeters in the past.....gets you no where in being kind... their again what do i know....
    Vinyl :
    AV Speakers
    I'm Mark.
    Sorry, you mean you were saving him from potentially being poisoned? Luckily, unless he is planning on eating any of the beryllium domes or grinding them up and inhaling them then he will be OK (from poisoning at least) - there's no beryllium dust/gas etc in them waiting to be released.
    If any of the drive units don't work I would recommend you claim a refund as replacement units are expensive and repair is, at best, a delicate procedure (if it can be done at all).
    100% Analogue
    Metallic Beryllium is perfectly safe when used in speaker diaphrams.
    I'm Dan.
    Yes this.....I really dont know that much about these hence was trying to help encase...They were bought at auction so the chances of seeing the 500 again a slim....I cant see any reason why the wouldn't work the pictures look fine...
    Vinyl :
    AV Speakers
    I'm jamie.
    cheers all.
    yes bought at auction and was told they were working before being entered for sale,if by chance somethings a miss i will probably break (which is a shame) due to the cost of replacement drivers let alone one turning up in the first place for sale!
    i wait with bated breath
    Might be able to return them if not as stated
    Grant ....
    OPPO BDP-103D DARBEE - JBE SERIES 3/M55E/EMOTIVA XPS1 - TWIN PRO MONOBLOCK AMPLIFIERS - XIANG SHENG DAC\PRE\HEADPHONE AMP - TWIN AVANTREE OASIS CLASS 1 BLUETOOTHS - AUDIO TECHNICA ATH-MSR7 & OPPO PM-3 PLANAR HEADPHONES - WIN10 JRIVER23, DEEZER HiFi - ECHO DOT - SMSL M6 MINIDAC - RPI/AUDIOPHONICS - FULL RANGE TWIN TELEFUNKEN/Q ACOUSTIC BT3/CANTON SUB - P.INSPIRED MAINS REGENERATED.
    No, because they were bought at auction, that doesn't apply.
    Martin
    Sony X505ES CD Player * NVA P90SA passive pre / Krell KSA50S Power amp * JM Lab Electra 926 loudspeakers *
    ''I like to be objective about my subjectivity.''
    - Geoff 'Walpurgis'
