Page 1 of 6 123 ... LastLast
Results 1 to 10 of 51
Thread: How good is better than CD?
    Default How good is better than CD?
    Hi All,
    I have an old turntable in my loft... not used for a LONG time... and not particularly special (the interconnecters are hardwired thin red/white types). I have a Roland Cakewalk interface I can use with Logic and I have The Orbs Adventures beyond Ultraworld on an early "classical" double vinyl copy.
    My question is this... would a 24/96 digital rip of a vinyl (as long as it's not got too many artefacts and I get a new stylus etc..) always be better than the lossless rip of the CD?
    Just curious!
    Thanks all.
    James
    Doubt it would be as good
    Grant ....
    OPPO BDP-103D DARBEE - JBE SERIES 3/B&O SP1/EMOTIVA XPS1/12V BATTERY - TWIN PRO MONOBLOCK AMPLIFIERS - XIANG SHENG DAC\PRE\HEADPHONE AMP\WE TUBED - TWIN AVANTREE OASIS CLASS 1 BLUETOOTHS - AUDIO TECHNICA ATH-MSR7 & OPPO PM-3 PLANAR HEADPHONES - WIN10 JRIVER24, SPOTIFY - SMSL M6 MINIDAC - RPI/AUDIOPHONICS/5V BATTERY - FULL RANGE TWIN TELEFUNKEN/Q ACOUSTIC BT3/CANTON SUB - P.INSPIRED MAINS REGENERATED.
    I'm AMusicFanNotAnAudiophile.
    Your recording quality is always going to be dictated by a number of things.
    The record player's setup is going to be very important, as is the cleanliness and condition of the records.
    You'll also need to ensure that you don't overload the ADC's inputs on signal peaks with too high a signal level, because that will cause distortion.
    What on earth does 24/96 have to do with anything?
    Chris
    Once we've made sense of our world, we wanna go fuck up everybody else's because his or her truth doesn't match mine. But this is the problem. Truth is individual calculation. Which means because we all have different perspectives, there isn't one singular truth, is there?
    I'm Will.
    +1
    Cheers, Will
    I'm Alex.
    Quote Originally Posted by Utterchaos View Post
    Hi All,
    Just curious!
    Thanks all.
    James
    I have yet to hear a good 'needle drop' digital file. Many people claim that they can make the needle drop sound indistinguishable from the actual vinyl playback, but like I said, I've never heard it with my own ears. Every vinyl rip I've heard so far sounded inferior to the original.
    Think about it for a second -- if indeed it was possible to make a vinyl rip indistinguishable from the actual vinyl playback, wouldn't many of us be prepared to drop good money for such rips? I mean, let's imagine someone has a top of the line analog rig (the dream turntable with the best fitted tonearm and cartridge feeding into the best SUT/phono preamp). Such configuration could cost tens of thousands of dollars, sometimes pushing the cost into the six figure territory. Few among us could ever dream of having such a system in our homes. Obviously, many of us have already had a chance, once or twice in our lives, to actually listen to such superior analog systems. And obviously, the quality of the reproduction via such a top notch system is vastly superior to many, if not most digital systems.
    Now imagine being able to do the 'needle drop' on such dream system where the digitized copy would sound exactly like the original playback. Hey, I'd be the first to plonk big bucks into buying such FLAC files! That would give me the luxury of hearing the best possible sound quality without having to purchase and mess with such precious front end.
    So the reason I'm skeptical that such vinyl rip is possible is basically there are no such perfect needle drop files available on the market.
    Alex.
    I'm Jez.
    Quote Originally Posted by magiccarpetride View Post
    Spot on. Nowhere near as good after digital recording IME and I find the whole idea of "needle drops" pretty moronic personally...
    Quote Originally Posted by Arkless Electronics View Post
    I'm Bernie.
    Needle drops to tape (R2R) can sound amazing! My experimenting with needle drops always loses something in the conversion and I usually only do them for vinyl albums I can't get a CD copy for, or the CD version is particularly dire.
    Bernie.
    Yes it is possible, firstly you need a custom built Class A stage RIAA preamp, secondly
    a type 1 DBX compander like a 150x, because you will never otherwise hear the full dynamic range
    LP's are capable of, thirdly a yamaha CDR HD1500. you need the hard to
    obtain and expensive integrated circuits DBX made. You need to align the DBX
    150x using the calibration procedure. Using a good moving coil cartridge and turntable needle drop
    and enjoy recording. Following recording playback - now compare A/B
    and you really need one of these to hear it all,
    http://www.stereo.net.au/forums/topi...grade-preview/
    Cheers / Chris
    I'm Russell.
    It may not be "better", per say, but many people do rip their vinyl albums into digital files for convenience. The real question is, does it sound good enough? And I think, if it's done well, it can be worthwhile. It's a recording of you playing a record, so why not just play the record? Convenience of course.
