Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: Please help clear up a question about MONOBLOCKS
    I'm AnDreW.
    Default Please help clear up a question about MONOBLOCKS
    What are the advantages of monoblocks over simply getting a power amplifier or preamp designed to have dual mono power supplies and output?
    SS CD Teac VRDS25X(Mega Modded) DAC Caiman SEG+Anker PSU DECK 1210 Mat Analog Studio Crystal Mods MN Base/Bearing/Platter+Ebony arm Board Feet Isonoe PSU Paul Hynes SR7EHD-27XL/DCSXL Ag DC lead/Jaeger(low-impedance) connector/3 StageRegs/Recapped PCB+No Pitch/Strobe/Light ARM SME V(Kondo Ag Rewire&Tags) MC Cadenza Black CABLES Arm Yannis SPD-4 IC Yannis 222 Litz+Ag bullets Power WAR PRE ATC SCA2 SPEAKERS ATC 50ASL STANDS Atacama PHONO Sugden Masterclass PA4 SUT Ortofon ST80SE POWER PSAudio P10
    Valve PRECroft Epoch(Mega Modded) AMP Sondex S100 SPEAKERS Tannoy 15"MG+RFC Warwick cabs+ Reference XO DECK Garrard301 MatTeunto GunMetal Bearing SPH Plinth Moldovan Arm SME 3012(Ikeda Ag wired) PSU NSC MCAg Meister SPU/DECCA Maroon CABLES Arm Yannis 420.5 Litz+ Speaker3mm2Ag IC Oyaide FTVS-510 AgWBT 0110Ag Phonostage Paradise
    I'm Phil.
    I used to have monoblocks , several times . I believe some folks like shorter speaker cable to get them nearer the speakers . actually my current class A single stereo power amp is better than any monoblocks I have ever had .
    modwright 36.5 DM /MSB s200 , / Marantz sa8005/bel canto 3.5, vbs , bel canto fm1
    sonos, . dct300/ /isotek sigmas /rfc/chord epic cabling/Kimber select/ harbeth shl5 plus/frugalhorn
    wouldn't think there would be any in general although some folk will think there is. I quite like monoblocks but its more for the look I think deep down. Like anything there can be extenuating circumstances
    Grant ....
    OPPO BDP-103D DARBEE - JBE SERIES 3/M55 SAS/EMOTIVA XPS1 - TWIN PRO MONOBLOCK AMPLIFIERS - XIANG SHENG DAC\PRE\HEADPHONE AMP - TWIN AVANTREE OASIS CLASS 1 BLUETOOTHS - AUDIO TECHNICA ATH-MSR7 & OPPO PM-3 PLANAR HEADPHONES - WIN10 JRIVER23, DEEZER HiFi - ECHO DOT - SMSL M6 MINIDAC - RPI/AUDIOPHONICS - FULL RANGE TWIN TELEFUNKEN/Q ACOUSTIC BT3/CANTON SUB - P.INSPIRED MAINS REGENERATED.
    I'm Oliver.
    Quote Originally Posted by hifinutt View Post
    I've just googled your MSB s200 and it looks phenomenal!! Looks to be dual mono ?
    Technics SP10 MK2 > Phonomac AT-1010 tonearm > Ortofon Kontrapunkt b > Rothwell MCX SUT > Wizard MM Valve Phonostage (Telefunken Valves) > Slagle AVC Passive Preamp > Firebottle Monoblocks (Telefunken Valves) > IXOS Speaker Cables > Pioneer CS-77A Speakers > Oliver's IC Cables Throughout
    I'm Steven.
    Often just doubles up the power. Quad QMPs are basically QSPs internally bridged. Some like Bryston can be switched externally into mono bridged mode. The only sense I can see in low powered valve monoblocks is to split the weight in half.
    The weight of big power amps is an issue, dual mono with two transformers and heat sinks would just be too heavy. Some stereo amps have just one transformer, think Hegel.
    Speaker cable length is irrelevant, just isn't an issue.
    Aries - Devialet 250 Pro - Harbeth SHL5+ 40th LE with a REL S/2
    Aries Mini - Audiolab M-One - Harbeth P3ESR
    I'm Martyn.
    Not totally relevant, but I understand the word is normally spelt without a 'k'.
    When I owned a Meridian 101 Series amplifier system,
    my Dealer told me the performance of the 105 monobloc ( or 'mono bloc' )
    was definitely superior.
    In the end I turned my 101/103 into a 101/103D setup
    That was back in 1979.
    Perhaps things have changed spelling-wise now we're in 2017...
    I'm John.
    Personally I found my Quad 405 monoblocks sounded better with short speaker cables and long interconnects so being able to site the amps close to the speakers can be an advantage.
    Using a pair of bridged stereo power amps as monoblocks will only give a 3db increase in maximum loudness in comparison to a similar single power amp used in stereo mode.
    I'm Neil.
    I have a "dual mono" amp i.e. mono amps in one case. Would there be any difference if they were in two boxes? I doubt it...
    Are there advantages with seperate power supplies for each channel? Yes.
    Mana Acoustics Racks / Bright Star IsoNodes Decoupling >> Custom Silent Media Server >> Halide Bridge USB (with AQVOX USB power) >> Pedja Rogic's Audial Model S DAC + Pioneer PL-71 turntable / Vista Audio phono-1 mk II / Denon PCL-5 headshell / Reson Reca >> LFD DLS >> LFD PA2M (SE) >> Royd RR3s.
    I'm Neil.
    Also I find that things might not sound as natural and coherent when you start bridging or biamping.
