Results 31 to 40 of 41
Thread: Taket Batpure - technical questions involving gain, stepup and maths ...
  1. #31
    mmn. i thought they were higher than that too. considered getting them but went another way
    montesquieu Guest
    I was very skeptical of reports that they did anything at all, until I tried a set. Whatever they are doing - and it could be some comb filtering effect - they certainly do have an impact on the sound, and not just in the high frequencies. Any supertweeters I've tried other than these put out something audible from 8-10k, these don't.
    I guess having two pairs would only increase the output by what, 3db? But might be interesting regardless.
    I did stick a reasonable quality gainclone in as an experiment, driving them directly from that, in an attempt to cover for the mismatch in sensitivity, but without a suitable measurement setup I was just messing around really, and things sounded more 'right' running them off the main amp.
  3. #33
    If that's the case, there was something wrong with the setup. The filter was rolling the units in too early from the description. There should be no audible output from supertweeters.
  4. #34
    montesquieu Guest
    Well you could certainly hear something from Townshends I've owned, and Tannoys, and Audiosmiles ....
  5. #35
    I'm Adrian.
    The takets are reportedly the only ones to be silent - I've toyed with trying their batpure further up the range, open backed as I think this could add some extra ambience - but the new Tannoy look sooooo lovely.
    Technics SP10 mk2
    Miyajima Shilabe cart
    Hashimoto HM-X SUT
    The Truth linestage
    Cary 805c SET amps
    Audio Note ANe-SPX speakers
  6. #36
    I set up my own supertweeters and filters, which were carefully tuned to avoid audible output. But, you could certainly hear a difference in the sound when they were taken out of operation.
    I've not used any for years though. I have many suitable drivers, but can't be bothered to be honest.
  7. #37
    Quote Originally Posted by farflungstar View Post
    All supertweeters will seem silent if used properly, i.e., filtered to come in above the audible treble output from the main tweeter.
  8. #38
    Ive heard output as well but if, as Geoff says, the right filter is on it, you shouldnt
    I have external crossovers placed next to my amp. Could I run these things straight from my tweeter terminals i.e. post crossovers or would something nasty happen impedance wise ?
  10. #40
    montesquieu Guest
    Quote Originally Posted by Chris View Post
    That's what I do. Their impedance is very high and I'm repeatedly assured that it's nothing to worry about.
