Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: Taket Batpure - technical questions involving gain, stepup and maths ...
    montesquieu Guest
    Default Taket Batpure - technical questions involving gain, stepup and maths ...
    Intrigued by another thread I've stumped up for a pair of these
    http://www.taket.jp/batpure/batpure.html
    The specs are interesting, on the face of it about 70db (1 watt/1m I assume though that may well be wide of the mark), while the impedance is 4 kohm - I actually have little conception of what that means when it comes to a transducer but it would appear to be a bit odd.
    My Tannoys are 90db/1w/1m and I am keen at least to try to match things.
    I've tried all sorts of supertweeter experiments over the the years - probably most successful with Quad ESLs and Townshends - and had come to the conclusion that the 'benefits' they offer are usually are usually well in the audible band ie they fill in for a perceived gap in audible HF, where one exists. Though I have been intrigued by some experimental evidence that the body can somehow perceive frequencies far higher than our ears can be measured at (and avoiding for now at least the question of whether there's any meaningful programme material 'up there' - I'll be using mainly vinyl and my EAR 912 measures up beyong 50khz).
    It's been suggested elsewhere that a step-up transformer of around 1:10 - easily available for phono use - might be about right to boost things from 70db to 90db, but I'd like to run that past the mathematicians here as surely that 4kohm must come into play. Also questioning whether an off the shelf phono stepup would have any useful (in phase at a minimum) frequency response above 20 khz.
    Some people have got around all this by using these Batpures with dedicated amplifiers - would obviously need to be more sensitive than my 1v power amp, though that's not too hard - but it would seem that the only way to set the correct level for this sort of arrangement would be with a dedicated high frequency measuring device - not many microphones will read at 50khz.
    This is only a bit of fun, for interest's stake and I don't want to spend a packet on it - but people have reported good results with these things and the wife complained recently on coming home from the house of her old professor (they have top end Tannoy supertweeters) why we don't have any as she thinks they add 'air' (we've measured her ears to 18khz rather better than my 11 khz so it may well again be the audible band she is talking about).
    Anyway, I'm keen to give the supertweeter idea one last go and would appreciate the technical viewpoint.
    I'm AMusicFanNotAnAudiophile.
    Why not just hang them off the back of the speaker terminals, as suggested on the website?
    You won't damage them.
    Chris
    Common sense isn't anymore!
    I'm Peter.
    Bat-tweeters!! I don't remember Adam West having those ...
    It says max voltage is 150 volts, so using a transformer to up the voltage at your main speaker terminals by 10x might be taking it beyond its limits? Depending how they work, it may well be that you don't get any more volume from them by increasing the voltage, anyway. Better, maybe, to stick little horns on the front of them?
    I'm Jez.
    Head amps will generally go beyond 100KHz no problem. 1000KHz is quite possible.
    I'm Jez.
    This may be relevant for some with supertweeters and vinyl.... phono stages which use series feedback RIAA don't continue to roll of the top end after 20KHz in the way the RIAA standard requires and could potentially have far too much output at say 40KHz.... Without seeing a circuit diagram for an individual unit I can't say which are affected. Passive eq and other types of active eq are not a problem in this area but series feedback eq is not in any way unusual, in fact it's the most common method in integrated amps, older units and some high end gear uses it too.
    montesquieu Guest
    Jez, I'll be in touch directly, you might have answered my question!
    I just bought a second pair from a neat little project I've planned for my Tannoys.
    PRE
    I'm Brian.
    I'm planning to do this too Andy
    Please keep us posted on this .
    Regards
    Brian
    Amplifier : Sony TA FB740R
    Speakers : Tannoy 637
    I have a variety of supertweeters, but currently use none with the Tannoys. Tried ribbons and moving coil and found the nicest results were from Celestion HF2000 units. They just seem to blend in with the Tannoy top end well.
    montesquieu Guest
    Jez and I discussed an active solution which is possible but I'm still curious about finding an autoformer that would do the necessary signal boost ... anyway the Batpures are on their way so we'll see if they do anything out of the box without a boost - who knows?
