Results 1 to 10 of 15
Thread: Conrad's custom arc generator.
    I'm Nick.
    Default Conrad's custom arc generator.
    Help needed chaps.
    Apart from pivot to spindle distance, what other figures do I enter
    For a mission 774.
    For the life of me I can't get the effective length of 229mm as in the
    Manual.
    Cheers
    Nick.
    I'm jamie.
    Quote Originally Posted by Nickfna View Post
    Help needed chaps.
    For a mission 774.
    Manual.
    Cheers
    Nick.
    thats all you need to do isn't it?
    i also click on the IEC tab as well.
    hope that helps.
    My System
    John Wood KT88 Amp.
    Paradise Phono Stage
    Sony TTS-8000 Turntable.
    PMAT-1010 MK6 Tonearm.
    Ortofon Cadenza Bronze
    Sony X555ES Cd Player
    Yamaha NS1000m Speakers
    I'm Angus.
    Default Mission 774
    There is clearly an error in the manual for the 774.
    If the effective length is 229mm, and the pivot-to-spindle is 215.4 as shown on the sketch in the manual, then the overhang is only 13.6mm, well less than that for a Stevenson alignment.
    If you assume that the offset angle is 23.5 deg, about right for Lofgren A on a 229mm arm, then a pivot-to-spindle of 215.4 gives you one null point at about 140mm radius, and a distortion peak of 2.5%.
    It will be worth trying to measure the offset angle (I can't find it specified anywhere), and then look at alignments with that offset and 215.4mm pivot-to-spindle.
    Hope this helps.
    regards
    Angus
    I'm Nick.
    Thanks for the replies guys.
    Tried your suggestion Jamie, the best i can get is the Stevenson A settings which give
    the effective length as 231.258 and an overhang of 15.858.
    Don't know if there is an error in the manual Angus, but it's bloody frustrating.
    I'm jamie.
    why not just go with the 215.4 mounting distance that seems to be right judging by the web and move the arm back or forth to get your alignment dialed in,in my way of thinking the effective length will be different depending on what cartridge you use so it cant be set in stone,the mounting distance however is.
    My System
    John Wood KT88 Amp.
    I'm Nick.
    Just found this
    http://www.hifisentralen.no/forumet/...-original.html
    These measurements are the same settings as what you advised Jamie, cheers
    I'm inthescottishmafia.
    Hunter S Thompson
    I'm jamie.
    where's all the 774 boys when you need them?
    their quick enough to shout my arms the best in the world,a technical question is asked and their no where to be seen!
    disclaimer,the above is in jest!
    My System
    John Wood KT88 Amp.
    LOL just did!
    Hunter S Thompson
