Results 1 to 10 of 15
Thread: Van Damme 6mm
    Default Van Damme 6mm
    I'm using van Damme 4mm studio speaker cable it, really can't fault it, but you know how it is, it s there anything to be gained going to the 6mm stuff?
    The 6mm really is top notch.
    Quote Originally Posted by Floyddroid View Post
    An improvement over ,,4mm?
    I did just that and yes it is an improvement
    Alan
    I'm jamie.
    i may give this a go too as im using the 4mm.
    let us know how it sounds please.
    My System
    John Wood KT88 Amp.
    Paradise Phono Stage
    Sony TTS-8000 Turntable.
    PMAT-1010 MK6 Tonearm.
    Ortofon Cadenza Bronze
    Sony X555ES Cd Player
    Yamaha NS1000m Speakers
    Quote Originally Posted by 337alant View Post
    Alan
    Thank you
    I'm Simon.
    Not sure if there would be much point unless you're running really long cables (5m+?) or like the look of thicker cables.
    6mm gets a from me. Its trumped a few cables.
    PRE
    I'm Allen.
    I have the 6mm version , but have not owned the 4mm version
    I am happy with the 6mm but they are rather chunky looking and blue
    yes my 4mm is blue, i was thinking of the 6mm version that Mark Grant sells it seems to have a transparent covering that might suit the living room decor better just wondered if it might be a better cable too
