Results 1 to 10 of 19
Thread: Rel stampede speakon connection?
    I'm paul.
    Question Rel stampede speakon connection?
    Now my new Sophia Electric 91-01 300B monoblocks require the speakon cable to be connected to the left/right + speaker posts, and the negative core to be connected to the earth post on the pre-amp, "BUT!" ~ I don't have a pre-amp!
    Could I connect the negative core to the Cary dac (earth) chassis instead?
    thanks!
    John Wood 6L6 Valve Amp, with:
    6L6GC Russian Original (no logo) Output Tubes 4x, supplied by J.Wood.
    ECC81 Mullard NOS Input Tubes 2x
    12AU7 (ECC82) Brimar NOS Input Tubes 2x
    Wilson Benesch Actor Loudspeakers.
    REL Stampede Subwoofer.
    Cary Audio 100t Dac.
    M2Tech Hi-Face 2 RCA USB to S/PDIF (co-axial) converter.
    HP Pavilion G6 - 2382sa D0Y14EA#ABU + "The Teddy" 19/3 - 19V 3.5A LPSU.
    The Missing Link Ultra-Pure System ~ EPS-100 ~Audiophile Silver Un-switched Double Wall Socket +
    APC ‘SurgeArrest’ Surge protector - PM1W-UK (Schneider), + AG500P Power Inspired mains – ‘pure sine wave’ re-generator.
    Sennheiser HD 558 headset.
    I'm Adrian.
    I've never heard of that before, not on a monoblock. Are you sure? I might be ignorant of course.
    Sure someone will know - but I'd wait for advice....
    Technics SP10 mk2
    Miyajima Shilabe cart
    Hashimoto HM-X SUT
    The Truth linestage
    Cary 805c SET amps
    Audio Note ANe-SPX speakers
    I'm paul.
    Quote Originally Posted by farflungstar View Post
    this is shown in the Rel Stampede user manual, page 11/12 but I cannot attach the file? (maybe too big), however it is online!
    cheers!
    https://www.manualslib.com/manual/14...page=11#manual
    I suspect the black and green wires are there simply to provide a pallitive measure of shielding. I would either ignore them, or connect them to a mains earth (such as the metal work of your DAC).
    I'm Adrian.
    It says when using high powered connection to connect ground to ground of 1 ground connections on amplifier but not to both - nothing about preamp - or are you connecting it differently?
    Technics SP10 mk2
    Hashimoto HM-X SUT
    The Truth linestage
    Cary 805c SET amps
    I'm paul.
    cheers, this is what I would think to some degree!
    I'm paul.
    ...diagram shows pre-amp?
    I'm Adrian.
    Sorry I was looking at the integrated in the link.
    Technics SP10 mk2
    Hashimoto HM-X SUT
    The Truth linestage
    Cary 805c SET amps
    I'm paul.
    never mind!
    I'm paul.
    Yes, decided to get this grounding post for the back of the DAC:
    https://www.hificollective.co.uk/com...arth-post.html
