Page 14 of 17 FirstFirst ... 41213141516 ... LastLast
Results 131 to 140 of 161
Thread: Digital audio vs vinyl
  1. #131
    I am surprised your Hi Rez files always sound better as this had not been my experience as some of the mastering can be s@!t on Hi Rez material?
    Hi Jim,
    I should've said that they only always sound better, *given* that the recording and mastering quality allows so
  2. #132
    okay replace 'guarantee' with 'bet any amount of money you like'
    Ha - you shouldn't issue me with challenges like that, as I have a habit of ensuring that it bites those on the bum, issuing me with such a challenge!
  3. #133
    In this case I'm safe as houses
  4. #134
    Hi Chris
    But not all sounds recorded were via microphones, Keyboards and synthesizers possibly had some output at those frequencies
    where connected directly to a recording device. Sadly mixers would tend to limit upper frequencies, but also adding frequencies of
    their own.
    Without researching every instrument used by every band in every recording capable of having frequencies above 20khz that might or could have been recorded directly - now there's a task for a Sunday afternoon just after a good lunch and a quick read of Three words daily to
    prepare one's self , evidence points that the recording devices were capable. Here are graphs of 15ips tape machines frequency response, http://www.endino.com/graphs/ quite a few showing rising frequency response above 20khz. a 30ips would improve further. A Neumann VMS70 lathe used in direct to disc recording its SX74 cutting head had frequency capability of minus 3db at 25Khz
    Adding to the complexity of discussing frequency is of course speed stability and phase coherency. It is perhaps where these
    attributes of a recording are attained, that frequencies above 20khz become possible to preserve correctly.
    And there is always the future, where 50khz recording devices can be used.
    Cheers / Chris
    The fact remains that the majority of microphones used to record many of the classic albums of the 60s and 70s (which still make up the majority of recordings that get rehashed as "Hi Res") didn't do.
    Take yer good old Shure SM-57 - it's quoted frequency response is 40Hz-15KHz.
    It was developed for recording orchestras.
    It's not known as "the sound of rock" for nothing, because it's suitable for any job - drums, guitar, vocals, you name it, and it has been used for all of those jobs over the decades.
    It is still widely used.
    It's similar with the Shure SM-58, only it's response is 50Hz-15KHz.
    It's still the first choice stage mic of many artists, and it's still used in studios too.
    That's just two legendary microphones.
    Look at something more recent from Neumann, such as the TLM 103 - its response is quoted as 20Hz-20KHz, but it nose dives from around 16KHz.
    They're all great sounding mics, and will continue to be used for decades to come.
    They're not going to get thrown out because the frequency response doesn't go up high into the areas where bats use sound for echo location.
    I'm not saying that microphones that can capture sound above human hearing aren't out there.
    They are, and they're expensive.
    They're usually in the domain of the top flight recording studio, and they're getting thinner on the ground as each year passes. Even the mighty Abbey Road Studios has had its share of financial insecurity in recent times.
    And when you weigh up that you can buy ten SM-57s, for the cost of one Sennheiser 8050, which do you think is going to continue to be the most widely used?
  5. #135
    But this overlooks a fundamental which is that we can't hear these frequencies. The idea that frequencies above 20Khz affect how we hear frequencies that are audible is, as far as I am aware, idle speculation/clutching at straws. If anyone has a link to something suggesting otherwise please post it.
  6. #136
    EDIT with direct injection recording the frequency limitations of the desk must also be take into consideration
  7. #137
    See Post 124 and this article http://wilson-benesch.com/reviews/Li...C_Sep-1998.pdf
    the work done by David Blackmer into the ability of human hearing to perceive sounds above 20khz
    Yes mixing desks are capable of limiting frequency, and must be improved. On the plus side fets and mosfets
    are capable out to 100's of Mhz if not Ghz
    It open's many possibilities when we think above 20khz for both recording and playback.
  8. #138
    I find a supertweeter affects what I can hear quite noticeable and I can't consciously perceive sounds above 10kHz.
  9. #139
    I'm Jez.
    Not a lot of people know this... (and I only said to blow the bloody doors off!) but phase changes begin to have an effect around 10 times earlier in frequency (at both extremes) than amplitude. This is one of the reasons I usually produce kit with <1Hz - 200KHz+ type frequency responses.. Also the ear is far from linear and can produce intermodulation distortion so, if we have two frequencies of say 24KHz and 26KHz there will be some 2KHz and 50KHz produced
  10. #140
    That's not the same thing though is it? Isn't it the case that most amplifiers are not bandwidth-limited is not because we can actually hear anything at that frequency but for other reasons unrelated to audible frequency reaponse?
