Page 5 of 9 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 90
Thread: Best dual concentric
  1. #41
    I'm Adam.
    Consider looking out for a pair of Goodmans Imagio loudspeakers with their ICT drive unit - they are, strictly speaking, the only true full range driver out there.
    I would also advise caution where 'whizzer' cones are concerned. I generally find they are best off left in the front doors of cars where your ankles absorb the worst of their distortions!
  2. #42
    I'm Adrian.
    They look very interesting...
    Technics SP10 mk2
    Miyajima Shilabe cart
    Hashimoto HM-X SUT
    The Truth linestage
    Cary 805c SET amps
    Audio Note ANe-SPX speakers
  3. #43
    I'm Jez.
    Whilst not a fan of the full range drive unit generally I was reasonably impressed by a pair of Goodmans axiom speakers a year or so ago... They could have done with a conventional tweeter taking at say 8-10KHz though IMHO as, whilst not disastrously so, the top end was audibly down on what it should have been...
  4. #44
    I'm Alex.
    I still have a pair of the original Axiettes, not bad full range, put a soft dome tweeter with them using just a single 2uf capacitor as the crossover. A lot of the better Goodmans units were designed by Ted Jordan, later started up his own company, Jordan Watts.
    Spendorman
  5. #45
    Don't need a tweeter with my telefunkens
    I'm Ari.
    How's about a pic of those telefunkens please Struth ! I've never seen them .
    I recently purchased a pair of Goodman Twin Axiom 10's in solid pine boxes with yellow wood framing the funky front grille clothe . The box appears to be the original design for the 10's by Goodman . Round hole for port cut in front baffle with ~shoebox size box as a port inside the bigger box . Something like the 2nd design on this flyer :
    I've got them driven by Pioneer SM-83 in my workshop , they sound amazing . I push the bass on the SM-83 to 3 o'clock , and reduce treble to 11 o'clock ( where 12 o"clock is flat ) and it then sounds fine . With both flat it can sound a little screechy . Perhaps , when I have time again , I can measure and make a notch filter . but I really am quite happy with the treble a notch down and the bass up - they seem quite efficient too .
    A couple of years ago ( probably 7 ) in South Africa a pair of Tannoy Monitor Gold 10's , unused in original boxes , with original crossovers , sold for the equivalent of $500 . I can seriously kick myself for not buying them , they were available for a couple of weeks at that time too . I uhmmed and aahhed about it all too long , and then they were gone .
    Looked something like this ( although these could be 12" or 15" )
    http://www.troelsgravesen.dk/Tannoy_IIILZ.htm
  7. #47
    There is some. In here of the finished article. Will have look for one of a driver
    I think one needs to make judgements about full-range drivers on an empirical basis rather than making generalisations about "shouty" whizzers and excessively rolled-off treble. Yes some full range drivers do have these flaws but not all do.
    Listen first: then judge!
    Geoff
  9. #49
    Default Best dual concentric
    these are 10" drivers
    last one is inside the single drivers I did first. still sweet and must try them again soon
    I'm Dennis.
    Ari I ask a favour of you regarding the picture above of a corner reflex cabinet.
    When I was about 9 my Father built a corner reflex which looks very similar to the one on the left in you picture above, but it was for a Godmans 12" unit with a whizzer, and its front panel port opening was up from the base by about 6".
    He built the cabinet with the port, up from the bottom by maybe 6", and I believe that he inverted the box attached to the rear of the front panel so that its opening was pointing up to the driver rather than down to the bottom. This I think he did on on the misconception that by having the open end of the port box which had one 'end' missing, upwards instead of downwards, it would 'allow the sound out better'.
    Of course it would which ever way up work as a reflex for bass frequencies, but with it upwards the rear cone mid range would also be allowed out, and this is undesired. So I have a question which you may be able to answer.
    Do you have any references or diagrams showing a similar corner box but for a 12" unit that will allow me to determine which way up the box should have been placed?
