Results 1 to 3 of 3
Thread: AudioQuest Jitterbug with RPI
    I'm Josie.
    Default AudioQuest Jitterbug with RPI
    Hi all.
    Does anyone know if using an Audioquest Jitterbug would be beneficial with the RPI as I'm using a powered USB HDD?
    Thanks
    Jo
    Preamplifier: Croft Epoch Elite - Dual external PSU & Upgrades
    Amplifier: Tube Distinctions Copper Amp No. 5 using KT150's
    Digital: Raspberry Pi & ALLO Piano DAC & KALI - IQAudio DAC with SBooster Linear BOBW PSU & Trio DP700 CDP
    Turntable: Thorens TD124 MkII - Schopper refurbished
    Tonearm: SME 3009 S2 None Improved - Audio Origami modified
    Cartridge: Ortofon SPU GT
    Speakers: 15" Tannoy Monitor Golds in Lockwood Majors with Tannoyista Spec 3 crossovers
    Cables/Mains: Mark Grant Black Series mains cables & 6-Way power bar
    Cables/IC's: Mark Grant HDX1 Pure Copper + Custom made Silver/Gold interconnects
    Mains Other: Tube Distinctions/Mark Grant 'The Power Works' Digital noise mains power filter TD2414-MG - Nick Gorham DC Blocker unit constructed by Mark Grant
    I'm Neil.
    No it won't help at at all, because your hard drive only transmits data, and no clock signals. If you were plugging into a USB DAC, or USB to SPDIF converter it might help, even then, with a well-sorted connection you would not need to use a Jitterbug or "regen" device. I think these devices are designed for sub-standard USB inputs without galvanic isolation on DACs...
    Mana Acoustics Racks >> Custom Silent Media Server >> Halide Bridge USB (with AQVOX USB power) >> Pedja Rogic's Audial Model S DAC + Pioneer PL-71 turntable / Vista Audio phono-1 mk II / Denon PCL-5 headshell / Reson Reca >> LFD DLS >> LFD PA2M (SE) >> Royd RR3s.
    I'm Josie.
    Hi Neil.
    Many thanks for that, very helpful
    Regards
    Jo
