Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 55
Thread: VPI Turntables?
    I'm Neil.
    I own a used Scout. A very nice 'table and the nicest I've ever owned. I have never used a Nottingham, so I can't compare, but it does many things very well. The arm is of good quality, and the reason the wire sticks out the top, is because it is interchangeable. If you own more than one arm, you can mount different cartridges on each, and pick the arm right up, unplug it, and place the next one on. Although the extra arms are expensive to say the least, it's the reason for the design. Great speed stability, rock solid performance, super quiet, silent passages are just jet black. The Scout 1 and 1.1 have an acrylic platter, and the 2 has an aluminum platter. They claim the new aluminum platter is better, but I've heard it was just cheaper to manufacture than the acrylic. Mine has the acrylic platter and I love it. I paid less than half price used. And it may be the last table I will ever own?
    As for VPI the company, I am not thrilled with. I sent my 16.5 RCM in to be repaired and never saw it again! Most disappointing. Still makes me angry to think about that.
    VPIs look and always have like a professionally built item, Nottingham Analogue, not so much, particularly the tonearms, the finish on those is pretty basic - in my opinion. They do sound good though. I recall hearing a Mentor Reference in Fortress Audio in London years ago and I was very impressed with the sound it was making in their system.
    That's very bad customer service
    Regards Neil
    System 1 (Living Room) : AMG Giro turntable, AMG 9W2 tonearm, Air Tight PC3 cartridge, Passlabs Xono phonostage, AMG Reference armcable. Marantz CD7 CD player, Sony HAP Z1es Digital File Player + Audioquest Jitter Bug, AMR DP777 DAC + HP laptop + iFi Audio i power, Wireworld Starlight USB + Audioquest Jitter Bug, for computer audio, Audio Valve RKV2 headphone amp, headphones Grado GS 1000, Nakamichi CR5e tape deck, Balanced Audio Technology VK300se integrated amplifier, Anthony Gallo Reference 3.1 speakers. Cabling: Signal - Atlas Mavros, Audience AU24, Speaker - Atlas Mavros. Mains Cabling: Audience AU24, Analysis Plus, TCI. Mark Grant distribution blocks, Equipment tables Target Audio B series.
    System 2 (Music Room) : Loricraft Garrard 401 turntable + SME 5 tonearm + VDH MC10 cartridge + Graham IC70 tonearm cable, Modified Technics 1200 turntable + Triplannar 7 tonearm + VDH Frog Gold cartridge + Paul Hynes SR7 PSU, SME Model 20 turntable + Graham Phantom tonearm + Ortofon MC5200 cartridge + Graham IC70 tonearm cable, Balanced Audio Technology VK10se phonostage, Moon Andromeda CD player, Esoteric P5 SACD transport and P 5 DAC, Toshiba 9500 DVD Audio player, AMR DP777 DAC + Dell Laptop + iFi Audio i power + JKenny JKSPIDIF + Wireworld Starlight USB - for computer audio, Kenwood 8300 tuner, Revox B760 tuner, Magnum Dynalab signal sleuth, Leak Troughline tuner + EAR Stereo decoder, Revox B77 mk 2 & Revox A77 mk3 reel to reel recorders, Balanced Audio Technology VK52se pre-amplifier, Music Reference RM200 mk1 power-amplifier, Anthony Gallo Reference 3.5 speakers. Cabling: Signal/Speaker - Audience AU24, XLO Type6. Mains Cabling: Audience AU24, TCI. Mains distribution blocks Mark Grant and Russ Andrews, Equipment tables Clear Light Audio.
    I had an HW-19 briefly. It worked, but did not impress.
    I'm Neil.
    That was an entry level deck I think, never heard or seen one. Maybe a poor arm and cart combination with it.
    Regards Neil
    Quote Originally Posted by Dalek Supreme D L View Post
    It was fairly solid. but I didn't like the particle board top which just rested on four Sorbothane pads. They are prone to sag I believe, although mine hadn't. I put an RB250 on it. As I say, it worked, but that was about it. I should have spent the money on a TD150!
    I'm Neil.
    It was fairly solid. but I didn't like the particle board top which just rested on four Sorbothane pads. They are prone to sag I believe, although mine hadn't. I put an RB250 on it. As I say, it worked, but that was about it. I should have spent the mnoey on a TD150!
    Having never heard one, seen one or taken one apart I can't comment. Never heard a TD150 either.
    Regards Neil
    I thought everybody had one at some time.
    They are a very nice little turntable. In my opinion, with careful setup, they will outperform the TD160 comfortably. I regard these as being as good sonically as the TD125. With the benefit of no electronic complexity.
    I'm Paul.
    Why does everyone still think a higher price equals better quality.
    Do the math it cant, you cannot improve on the sound of the original, the Vinyl played on it how can a 100 grand turntable do anything better than a 10 grand turntable, the simple truth of the matter that no one wants to admit to even though there is a mountain of evidence is that a quite low cost system will attain 99% of the original sound off the vinyl once you spend a grand on a turntable you have probably maxed out what a turntable/Arm/Cartridge combination can extract from vinyl, spending any more is pointless, but those who do will never admit to that will they, if you have attained perfection how can spending money give better than perfection.
    Mod note. Edited dont use that term again or you will get a holiday. Youve been warned already
    Current setup Thorens TD-160 Mk1 with Denon DL-110 MC Cartridge, Pioneer A-70 Amp, Yamaha AX-592 Amp, Yamaha CDX-710 CD Player, Pioneer PD-4300 CD Player, Monitor Audio Bronze 5 speakers, Van-Damme Cables throughout.
    Quote Originally Posted by Paul-H View Post
    Hardly.
    I'm Tony.
    Sounds like you need to open another thread to discuss, bye.
    VPI Scout 1.1, Ortofon Quintet Bronze, Lesbox Tube Phono Stage, Xiang Sheng Dac 01A, Modified Yaqin MC-100B and Reiver Edingdale SR
    I'm Graham.
    He probably still drives a Morris Minor,after all spending anymore would be pointless.
    Analogue. Basis signature 2200,Basis Vector 4.Koetsu Red,Koetsu SUT,NVO SPA 11.
    Digital. Denon 2900,Jolida FX 11
    Amp. Pathos Logos,Minidsp dirac 22A.
    Speakers. Amphion Xenon.
    Airlink CBS 2000 bps
