I might add not all of these powerpacks are as great. I have one that doesnt sound so good. I reckon its something to do with the electronics in it. Will look out the name of mine for you.
I'm Luke.
Cheers, that would be great. That is something I did wonder about.
But saying that, the one I've just experimented with is a cheap no brand thing off of Amazon that was gifted to me by someone who bought it in error, and yet that still sounds better than my SMPS (admittedly a very cheap PS). If I could improve on that further with a decent one I would be well pleased.
Still undecided though, I may yet buy this new 5v PS from Allo though, if they ever get round to releasing it!
https://www.amazon.co.uk/Portable-Ch...keywords=iMuto
they do a bigger 30k size too
Switch. I got mine on eBay
I'm Luke.
Great stuff, thanks.
So the switch disconnects the battery from the pi without having to faff with about with cables, then you just plug in the battery into its charger, leaving it all in situ?
I like to set and forget but I think I could live with that approach
(I'm guessing that leaving the power supply connected to the battery while it powers the pi is a bad idea?)
Yup I don't think it outputs and charges but if it did it would need isolation This one doesn't if memory serves. I did have a switch for the charger too but found it better to just plug in when needed Cable is just beside it anyway and is easy to do. No hassle
I'm Mark.
As an owner of the Pi in combination with the Allo Boss and Isolator i feed my pi with an ordinary iPad charger and my Isolator/ Boss with a linear PSU made from a toroidal transformer in combination with a Tentlabs Heater Supply. http://www.tentlabsshop.com/DetailServlet?detailID=670
The result is a very, very nice sounding DAC streamer.
