Closed Thread
Page 4 of 9 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 82
Thread: Phono Stage Shootout
  1. #31
    Bigman80 Guest
    Ooooo. Looking forward to getting a listen
  2. #32
    I remember one particular shoot out at my first NEBO where Nick Gorams phono stage wiped the floor with everything else, it was so far ahead and very special indeed but again I think it was about £10,000
    Alan needs to hear one of these
    No I need to engage in a shoot out
    Ali, if you get to borrow mikeyb's Vivant is there a chance you could also borrow a stage off Nick?
  3. #33
    I'm inthescottishmafia.
    Would struggle tbh, he only has one. Can you make it to Owston?
    Hunter S Thompson
  4. #34
    RothwellAudio Guest
    ... I've been doing TRON mods
    Interesting. What modifications did you make?
  5. #35
    I'm Jez.
    I had a look in a Tron reference a couple of years ago... pretty bog standard generic topology very similar to 80's Audio research and Conrad Johnson models and many others besides... Not that there is anything bad about that of course, certain topologies do become well known and are known to work well and tend to become part of, lets say the standard repertoire (think of what proportion of SS power amps use a LTP followed by a single ended Vas and push pull followers... and how many valve power amps are pretty much the same design!). if it's the same as the unit i took a butchers at it has two gain stages then a cathode follower from which series negative feedback, including the RIAA, is applied to the cathode of the input valve. As one may expect, I have a similar design of my own that i designed several years ago in computer simulation. I never got round to doing anything with it but the idea was for it to be a mid price stage, £6-700 ish.
  6. #36
    Hi Jez, that's very interesting to know about the Tron reference. I can state categorically I wouldn't like it, without even hearing it.
    In my experience negative feed back equalisation is never as good as passive, hence why I always use passive. Yes there are compromises to be addressed but that's the name of the game.
    I think the 'standard repertoire' is also rather disappointing, I have found the same in the Convergence, but at least it uses passive equalisation, even though it is not accurate. I was hoping for some advanced design or a couple of 'tweaks' that can make a phono stage excell, but sadly not.
    The modifications:
    Both gain stages use standard cathode bias with an electrolytic bypass capacitor. That's a no-no in my book so they came out. Gain loss was 8dB.
    To improve the linearity of the second stage I bootstrapped it from the cathode follower output, also resulting in an increased gain of 6dB.
    The gain of the original circuit was high at 69dB, so a 2dB loss overall was quite acceptable.
    The depth of the soundstage was improved with greater resolution.
  7. #37
    I'm Jez.
    The modifications:
    I didn't go as far as reverse engineering the reference so my post is based on what I could see from the top of the board... IIRC it also had electrolytic bypass caps. I assume you have changed the eq network to compensate for removing the caps? I always design for extremely accurate eq as what's the point of going for excellence elsewhere if one hasn't got the RIAA right and the thing has slightly too much/little bass/treble etc IMHO.
  8. #38
    I'm Graham.
    Quote Originally Posted by Arkless Electronics View Post
    There is nothing remotely similar in the Tron Seven Reference phono stage to ARC and Conrad Johnson models of the 80's other than the 3 valves in the circuit. There is certainly no feedback in the circuit apart from the cathode follower output stage and certainly no link back to the input stage...
    Graham Tricker
    G T Audio/AudioMeister/TRON
    01895 833099
    Personal System
    Analogue: TW Acustic Black Night Turntable, SME M2-12R Tonearm, Ortofon 90th Anniversary SPU / TW Acustic Raven LTD Turntable, TW Acustic 10.5 Tonearm, Transfiguration Proteus / Studer 807 & Studer 810 Tape Machines.
    Digital: Innuos Zenith MKII / Tron Seven GT DAC.
    Amplification: Tron Seven GT Mono Phono stage x 2 / Tron Nemesis Preamplifier / Tron Telstar Power Amplifier.
    Loudspeakers: Cessaro Liszt Horns.
  9. #39
    I'm Jez.
    Quote Originally Posted by G T Audio View Post
    I only took a quick gander at the top of the board and the layout suggested this topology. I didn't even lift the board as it was only in for a check over before being sold. I don't reverse engineer anyone's current kit, not cricket It's your design so I'm sure you're quite right.
  10. #40
    I'm Graham.
    That's good to know because there are over 1000 satisfied Tron Seven owners around the world who are very happy with theirs... Also the Tron Seven has been in continuous production for 11 years...
    BTW I have the serial number recorded on the Convergence you have modified so the 2 year warranty is now void.
    Graham Tricker
    01895 833099
    Personal System
Closed Thread
