Results 1 to 7 of 7
Thread: Quad 405
    Default Quad 405
    What would you pay? Serviced and resprayed.? BTW it's not mine,but mite be
    Is it a 405 or a 405-2?
    Good point, 405-2
    £200 - £250 for a decent clean unmolested example. Maybe upwards of £250-400 for an example with upgrade work from Keith Snook, Da Da, Net Audio etc....
    PRE
    Thanks Andrew, it's a chap on eBay,seems to do up older quads ,I'm tempted
    I paid £400 for mine but it does have all the latest Net Audio mods installed. I occasionally run mine in a 3rd system and it really does sound very good. I dont think you'll be disappointed if you purchased one. You should be able to get your money back pretty easy if you decided to sell on.
    PRE
    Cheers Andrew, I ended up going for a Cambridge azur 651w power amp instead,though the quad was very tempting
