Results 1 to 7 of 7
Thread: Replacing Rega RB300 with Jelco SA-750D
    I'm Alex.
    Default Replacing Rega RB300 with Jelco SA-750D
    I'm using modded Systemdek IIX with Rega RB300 tonearm (rewired). Been hearing from many sources that Jelco SA-750D is a better tonearm, especially because I'm using Denon DL-103. My question: which length Jelco should I order for the replacement?
    Alex.
    I'm Kevin.
    Rega RB300 - Mounting distance platter center*to arm hole center 222mm which makes the SA-750D the closest. Distance of the tonearm pivot to spindle is 214mm.
    The SA-750D has an Effective length (from the tonearm pivot to stylus point) of 229mm. If you want a longer one, you need to drop the "D" and go for the "E" or "L".
    Kevin
    blackstar Guest
    I've gone from RB300 to 750D and I would heartily recommend it. It is an incredibly versatile arm.
    I think you're obliged to use a 9" arm on a Systemdek, since there isn't room for a longer arm.
    I'm Alex.
    Thanks, I needed a confirmation for that (wasn't sure if there's even a possibility for longer arms).
    Alex.
    I'm Alex.
    Quote Originally Posted by blackstar View Post
    Yes, I'm definitely gonna do it, just needed to confirm the correct length.
    Alex.
    I'm Alex.
    Thanks mate.
    Alex.
