Are you bringing your turntable to NEBO, Ken?
Edit (later) ... I see from the NEBO thread, that you are ... excellent!
Peter - Yes, as you spotted.
My Denon DL-301 mkII crapped out, when the cantilever just fell out.
So I am using a pre owned Ortofon MC20 Supreme at present, nice cartridge.
To be played through a Pro-Ject Phono Box RS/Pre Box RS, my semi active crossovers/Nakamichi Power Amp and three way speakers.
The later is all a work in progress, but sounding pretty damn good for a lash up.
Imo most turntables come with a nine inch arm to keep the footprint down to a reasonable size.
Ralph.
I'm Deleted.
Parallel trackers are fine in theory, but invariably involve more complications and issues than a pivoted arm. I am yet to hear a parallel tracker that was actually a good tonearm, so for me it's a question of balancing the various technical compromises and those are far easier to reconcile with a pivoted arm.
Here's an interesting take on the issue - a pivoted tonearm that tracks like a parallel tracker, without any articulating linkages in the armtube or headshell:
I hear this often, but no one will define what the complications or issues are.
A parallel tracker has far fewer issues to overcome in my opinion.
The whole null point compromise, bearing friction and anti skate requirement of a pivoting arm, don't exist on an air bearing linear tracker.
Low end pivoting arms are cheap to produce and that's about it. By the time you get to a decent quality pivoting arm, there is little difference in cost between the types.
The engineering principles of my linear tracker are far simpler than your average pivoting arm.
http://www.trans-fi.com/terminatortonearm.htm
