Results 1 to 10 of 18
Thread: FS: Tsakiridis Aeolos Super Plus KT120 valve integrated amplifier
    I'm Robert.
    Default FS: Tsakiridis Aeolos Super Plus KT120 valve integrated amplifier
    Made in Greece. Well known in Europe but not so much in the UK so represents a bargain for someone. See the links at the bottom which also gives more photos.
    This version is the ‘Super Plus’ so while it then sports the KT120 valves, it comes stock out the factory with better output transformers, WBT output speaker posts and has the internal signal wires are by Van den Hul.
    I upgraded the internal fuses to Hifi Tuning Silver Star types (for the believers)
    I have the original box and manual plus remote. Box is in fairly good nic but the internal packaging is only 80% complete or I just don’t know how to pack it properly. It will be securely packaged up though.
    Also comes with the original tube cage to prevent burnt fingers.
    Due to weight and sensitive nature of the product, I’d prefer collection allowing one to hear the amp as well ��
    Biasing is currently set up for my 8 ohm speaker load – you will need a mutimeter to set them differently if needed.
    Runs 60w in class AB but can bias’d into class A (which I have never done). But the tubes won’t last very long in class A.
    Comes with the stock TungSol KY120’s and ElectroHarmonix 12AT7’s (new issue valves) – not those seen in the photo.
    £600 collected ��
    £625 posted
    Technical Specs:
    Push-pull, Class AB valve integrated amplifier
    Tube complement: 4x 12AT7, 4x KT120
    Power output: 60W per channel
    Inputs: 4x RCA stereo line level
    Outputs: 1x RCA tape loop, WBT speaker terminals
    THD+N: 0.38% (1W at 1kHz)
    Intermodulation distortion: 2.1% (60Hz/7kHz, @ 1W)
    Frequency response: 20Hz-20kHz ±0.2dB
    Signal to noise ratio: 85dB
    Weight: 12kg
    Manufactured by: Tsakiridis Devices of Greece
    Reviews:
    http://www.hifiplus.com/articles/tsa...ted-amplifier/
    http://www.tnt-audio.com/ampli/tsakaridis_aeolos_e.html
    This is a lovely valve amp. A bargain at this price.
    I'm Robert.
    Still for sale ��
    I'm Robert.
    Bump
    I'm Robert.
    Bump
    PM sent yesterday
    I'm Robert.
    Thanks - replied
    I'm Robert.
    I would buy this if I hadn't just bought a pre yesterday.
    I'm Robert.
    Bump
