Diminutive but very nice sounding FM tuner. 9 months old and in first class condition complete with wall wart power supply and remote.
Manufacturer's blurb:-
'' The Tuner Box S is an intelligent, compact and effective FM tuner with a real industrial feel too it's build-quality and ease of use.
The 'S' version of the Tuner Box is superior to its predecessor by including a better tuner module with improved sensitivity into the same footprint. The only other differences from the original Tuner Box are in the thicker, more stylish front-plate, and the smaller power supply that helps the unit comply with new 1W Standby regulations outlined by the European Union.
This small FM-only tuner is fully-loaded with high-quality audio and useful features. 99 station presets are more than enough to store your favourite radio stations. Tuner Box S can ideally be used in combination with other Box design components, but equally sits well in any system.
The included full-function IR-remote control and the high-contrast dot-matrix display make this unit a delight to use!
Key Features:
•Low-noise FM tuner
•Manual or Automatic Tuning
•Adaptive noise reduction
•AFC – automatic centre tuning
•99 presets
•High-contrast dot-matrix display
•Display shows:
********* ******** • Frequency
********** ******* • Preset Number
********** ******* • 'Centre of Station' marker
********** ******* • Stereo or Mono Reception
********** ******* • Signal Strength
•Trigger-input for switching on/off
•Outboard power supply included
•Metal case shields the electronics from vibrational and electromagnetic interference
•Gold plated RCA connection sockets
•Full-function IR remote control
Technical Data:
Tuning Range, FM-Band: 87.5 - 108.5MHz (50kHz Steps)
Programmable Presets: 99
Frequency Response: 20Hz - 20kHz (± 1dB)
Noise Floor: -50dB
THD: 0.05% / Df 75kHz And F Mod 1kHz
Stereo Separation: 30dB / Df 75kHz And F Mod 1kHz
Sensitivity:
*7dB/µV Mono
*17dB/µV Stereo
Antenna Input: 1 x Coaxial DIN-Socket (75Ω)
Output: 1 Pair RCA/Phono Sockets (Line-Level)
Trigger In/Out: 2.5mm Jack
Outboard PSU: 9V / 300mA DC
Dimensions: 103 x 36 x 115 (Incl. Sockets)
Weight: 565g (Without PSU) ''
Currently retailing at between £139 - £190.
Asking £75 including UK delivery.
[IMG][/IMG]
