I've got a rega rb300 overhauled by jonnie at audio origami, on my 1200, have also had a 309 which I think is the best bang for the buck from sme as it has azimuth adjustment, but to me I think the rega is more alive and musical, I use a hana sl cart which is great with the rega, I use a metal erm plate but am thinking of trying the ebony or African black wood version.
Modded td160 super Thorens ol encounter arm hana sl cart, angle audio studio pro mc virtual battery phono amp with separate psi, Onix pre and mono amps, Onix CD player, Onix BWD and soap tuner. B&W dm2 speakers or super pencil 12 speakers, atlas cables, seperate mains power supply with earth spike.
I'm Mel.
This is my view of the SME/Rega difference. I use an SME V on a Michell deck and absolutely love it. The engineering is excellent and it is one of the easiest arms to set up with a cartridge I have ever come across.
However, my main listening deck tends to be a Rega or Techie - both with RB 300 arms and the reason is that more 'alive' sound - though frequency extremes are not as clear or sharp. Maybe an SME needs a bright cartridge to balance its smooth nature.
I always tend to think records played on the SME sound like studio albums while the same on a Rega arm sound more 'live'.
My early OL Rega based arm errs more on the SME type of sound but in all honesty it has spent most of its like in a box as its sound is not to my liking.
Mel
I'm Russell.
Anyone mentioned grounding? I'm using SME V on Sound Hifi metal arm board. I've tried a thin insulating film between the arm board and deck just to see if there was a difference. Everything grounded sounded better to me. Grounding components and both ends of interconnects (single ended or balanced) is kind of the accepted standard isn't it? Something to consider anyway but I ruled out insulating arm board materials after that.
Russell.
