Results 1 to 9 of 9
Thread: Help needed- anyone a qualified electrician?
    Default Help needed- anyone a qualified electrician?
    Hi I've a couple of questions with regards spot light specs and regulations, could anyone answer a couple of questions?
    PRE
    I'm Allen.
    Yes
    Employ a electrician
    It's not as simple as that. I've been quoted a set figure to install 30 spot lights and I think I'm being ripped off with regards how much each unit costs, hence the question to start the thread. I'd like to look at alternatives to his recommended lights and wondered if I needed to follow specific building reg specs with regards the lights that install.
    PRE
    I,d say min £25 each fitting plus the materials. Qualified sparks are expensive.
    Thanks for your input Grant.
    PRE
    I'm Ian.
    I had a quote to replace eight halogen spots with LEDs an nearly fell over at the cost. The only real advice I can pass on is don't go for halogen spots, they get quite hot and blow on a regular basis.
    Turntable
    CD
    Network Player
    Cambridge NP30
    Amplifier
    Speakers
    Cables
    Headphones
    I'm Paul.
    Halogen bulbs (Lamps) are quite bizarre, the ones have tried in my home have blown if the cat next door f@rts yet the ones in my car last for years.
    Current setup Thorens TD-160 Mk1 with Denon DL-110 MC Cartridge, Pioneer PD-8700 CD Player, Yamaha AX-592 Amp, Yamaha CDX-810 CD Player, Yamaha KX-480 Cassette Deck, Yamaha TX-492RDS Tuner, Monitor Audio Bronze 5 speakers, Van-Damme Cables throughout.
    I'm Andy.
    Andy, drop Cornish Pasty a PM, he's a spark and might be able to help and only lives over the hill.
    Analogue
    401 / PU7 / AT33ev
    Digital
    Innuos Zen Mini Mk 3
    Topping D50s
    Caiman Seg & Dorado
    Cambridge CXC
    Amps
    Tron Seven Linestage
    Speakers
    Tannoy GRF Memory.
    Tannoy ST100.
    Quote Originally Posted by Andy831 View Post
    BONZA! Thanks mate.
    PRE
