Results 1 to 10 of 11
Thread: Whats the most tweakable MC?
    Default Whats the most tweakable MC?
    Just for fun could you suggest a MC cartridge which is very tweakable?
    My suggestion would be the Denon 103.
    PRE
    blackstar Guest
    It does seem to be, whether its nuding, rebodying, rebuilding....
    I'm malcolm.
    Audiophile Tosher
    I'm gordan.
    depends who's gonna tweak?
    you can recoil koetsu black with silver windings, give it boron cantilever with microridge tip for example with softer damping, for example. you will get an incredibly capable music machine.
    or if you have an alnico ortofon, like vintage SPU or SL 15, you can do the same treatment and you can go nude with it, basically removing most of the shell so it would look like a mad max lyra or so...
    Gordan.
    Speakers: Oris Swing MkII
    Amps: Thomas Mayer 300b/ Hiraga La Maison de L'Audiophile 20
    Preamp: Silver AVC by eng. Ferenc Lazar
    Phono Preamp: Shishido LCR by Solaja Audio
    Decks: Garrard 301 Martin Bastin reworked/plinthed with Fidelity Research FR64fx
    Garrard 401 in eng Ferenc Lazar solid wenge plinth with SME 3012/2
    Cartridges: SPU Spirit/ Koetsu Black revisited by eng. Salai/ Miyajima Shilabe
    Step Up Transformers: Tango MCT 999/ Ortofon T-5000/ Lumiere SUT
    Digital: Shigaclone by eng. Ferenc Lazar with Lampizator Amber II
    Wires: of sufficient length
    I'm Alex.
    ZU DL-103?
    Alex.
    blackstar Guest
    That's the after to the DL-103's before.
    I'm Timothy.
    I once "nuded" a Dynavector 10X4, uh, that's all I've got. I'll get my coat now.
    Holbo TT-Nag 110-Croft phono/Innuos Zen MK2/LinnenberG Telemann DAC-Preamp/LinnenberG Allegro monoblocs/Duevel Venus/LinnenberG Maestro SE-Senn. 660S DH Labs cabling
    Croft Series 7 amps, WLM La Scala, Naim Uniti1, Naim Nait XS3, Naim ND5XS2, Guru Junior
    blackstar Guest
    Quote Originally Posted by Frazeur1 View Post
    That'll do it though....
    I once nuded an ugly bit....i got my coat too
    I'm Timothy.
    Grant, was the coat for yourself or the other "nuded" bit?
