Results 1 to 10 of 10
Thread: Remote controlled power socket
    I'm Gareth.
    Default Remote controlled power socket
    Can anyone recommend a remote control power socket for a power-hungry integrated amplifier (Nu Vista 800) that won't affect sound quality?
    I confess to being one who believes in the benefits of sensibly-priced power cables, and adding an additional device in the chain doesn't sit comfortably with me.
    I have been looking for similar. Belkin used to produce a suitable unit but that seems to have been discontinued.
    Geoff
    Good find though it's not surprising they have stocks given that price. May bite the bullet anyway to save having to perform a geriatric limbo to turn my monoblocks on and off!
    Oooooops! Just realised it's a US socket type!
    I'm Gareth.
    These look interesting and might fit the bill:
    https://www.megamanuk.com/lightwaver...power-control/
    thought that was the type you wanted. schuko.. ah well... my big Belkin box is what I use. has 10 sockets on back and a switch on front. has filters in but guess you could disable them if you wanted... they come up from time to time.
    I'm Julian.
    I used a Masterplug remote control socket with my turntable and it worked very well. Battery lasted for ages.
    http://www.homebase.co.uk/en/homebas...ck-of-2-682609
    My mains block is more accessible now so I don't use it.
    Sonore Rendu - Cambridge Audio Edge W - Sonus Faber Venere 2.5
    I'm Gareth.
    PF40?
