Never warmed it up Ive tried carbon but didn't like it with fluid. Personally I use a tonar wet goat
Turntable : Project 2 Xperience Tone Arm & Cartridge : Project 9c Ortofon 2M Blue Phono Stage : Project Phono Box SE II Digital Source :Primare CD21 Integrated Amp : Primare I30 Speakers : ProAc 110 Headphones : Beyerdynamic DT770 Pro
Revox A77 MK IV 2 track 15 & 7 1/2 IPS
TEAC A-3300SX 4 track 7 1/2 & 3 3/4 IPS
Akai 4000DS MkII
http://www.analogueseduction.net/bru...ing-brush.html
yea olde goat
dont ask if your not intereted
Here is one of the best, if not most unorthodox advices on record cleaning I bumped into while doing my research:
"Here's what I do to clean my vinyl. One only has to do it once in their entire lifetime to protect the vinyl from a multitude of plays thereafter...... 1. Go outside on a full moon (must be raining and windy)... 2. Suspend vinyl from a silver stick at a 45° angle (silver stick must be blessed by either the god Apollo or myself. I charge the low fee of $19.99... try getting Apollo to show up after he dings your credit card! But hey, it's your choice.) .... 3. Walk male Siberian Husky exactly 16" from said vinyl. ...4. place Canine‘s LEFT hind quarter parallel to the vinyl... 5. Induce urination in said canine by dipping paw in bowl of warm water.... 6. Let rain & wind provide the final vinyl rinse. ... 7. Magic moonshine rays will then enter the pristine grooves and protect vinyl for an eternity thereafter."
Alex.
Weird shit!
I'm Clive.
I have always been a fan of these types of cleaner ever since I used a product from Lasky's called disc skin in the 70's.
http://www.nagaoka.eu/index.php?item...aid=67&lang=en
This version actually came with instructions recommending its use as an archival tool to protect records until you get round to using them.
I actually have one of these I purchased about 15 years ago but don't need to use it much because there is the cheap skate alternative of "PVA glue" that is now very popular.
I buy the MoFi stuff off the shelf, $30 bottle, (I've seen it on sale for $25 lately), and after cleaning a hundred records I've still got more than half left. I use the brush that came with my RCM, I don't scrub hard unless it's real dirty, using one of those overpriced MoFi brushes. I don't bother with clean water rinse, the stuff doesn't call for it. And hey, it works! I try not to stress about it. Whether to use alcohol, or not, or clean water rinse, well there is always more than one way to skin a cat. I'm sure there are many ways to clean a record that actually work. Just get in there and do it, see what works!
But the best by far stylus cleaner is the Zerodust. What I like to call the, "Booger in a box", just a sticky gob in a small plastic box, and you dip the needle into it. And the dust sticks in the goo, and leaves your tip clean. No chemicals, no liquids that may get sucked up the cantilever, if you've got an aluminum tube. And no having to stroke it with a tiny brush! Which accounts for crooked cantilevers half the time. Shop around and you can find them reasonable, even comes with a good magnifier in the lid to inspect your work. And it lasts forever, rinse and it's good as new.
