Results 1 to 4 of 4
Thread: My systems...
    I'm Seppo.
    Default My systems...
    Main listening area - Lenco PTP5 with Mayware-5 arm and Sonus Gold Blue cart. Amp: Pioneer Z1. Speakers: Monitor Audio Silver RS-1. A mediaplayer is also connected to my Squeezeserver controlled by the familys iPads and iPhones.
    Basement - Yamaha RX595 surround system and another Lenco 75 with an arm that slipped my mind holding a Denon 103r.
    The Cave - Lenco 75 dual platters with a Clearaudio Satisfy Ebony arm holding a Stanton LZH981 cart. Phonoamp is Salas Folded FSP found on Diyaudio site. Buffer is another Salas design - the hotrodded DCB1. Poweamps: 2 Quad 303's in monoblock configuration. Speakers - a few. In use now is Lin Kanns genII with a passive bassunit. Behind the curtains waits a pair oF AR-3's waiting to be finished.
    Bedroom: Another mediaplayer and headphone amp driving me to sleep - HD-650's and different in ear products.
    Every part here will be tweaked in some direction when time allows. I wil also se if tube amps fits somewhere
    Regards
    Hi Seppo,
    Welcome to AoS
    I'm afraid that the purpose of this section of the forum is to show pictures of your system(s), hence why it is called 'The Gallery'. Lists of kit only aren't acceptable.
    Therefore, if you want this thread to remain, you'll need to take some pictures of your system and post them here. Cheers!
    I'm Allen.
    Hi Seppo
    If you are not able to post the photos as you are NEW to the forum I will do this for you , Send me a PM and I will forward my email address
    I'm gone.
    Hi Seppo
    Yep, welcome to the forum.
    And that's a fascinating list of systems!
    ~~ do you like Lenco turntables?
    Some photos would be great - you have to use a photo hosting site for that like Photobucket.
    Audio Al can help you out to get started.
    Or there is a how-to-do-it guide here > http://theartofsound.net/forum/showt...king-to-Photos
