Results 1 to 10 of 15
Thread: Ikeda and Reed Tonearms at Ammonite Audio
    I'm Hugo.
    Default Ikeda and Reed Tonearms at Ammonite Audio
    We will soon be selling Reed and Ikeda tonearms from the shop. Why?
    Ikeda arms are directly descended from the battleship Fidelity Research arms and are one of very few genuinely high-mass designs available. High mass is very much a Good Thing with Miyajima cartridges, so an Ikeda tonearm is a natural accompaniment for any Miyajima. Retail prices (including VAT) are £5000 for the IT-345 CR-1 and £5495 for the 12" IT-407 CR-1.
    Reed hail from Lithuania and produce a number of tonearms with beautifully conceived and machined mechanical parts, with a number of different hardwood arm wands which each give different effective mass. We are concentrating on the Reed3P which is almost unique in allowing on-the-fly adjustment of both VTA and azimuth. The 3P is available in a range of different anodised finishes and arm tubes can be specified in Red Cedar, Wenge, Zirocote, Macassar Ebony, Cocobolo or Pernambucco hardwoods. Prices for the 3P, including VAT, start at £3200. Because of the wide range of options, these arms are mostly built to order.
    Have a read of the HiFi+ review at http://www.reed.lt/attachments/artic...3c-reed-3p.pdf
    I'm gordan.
    a reed tonearm played on possibly the best vinyl setup i've ever heard - platine verdier, reed 12" and koetsu red stone. ultimate!
    Gordan.
    Speakers: Oris Swing MkII
    Amps: Thomas Mayer 300b/ Hiraga La Maison de L'Audiophile 20
    Preamp: Silver AVC by eng. Ferenc Lazar
    Phono Preamp: Shishido LCR by Solaja Audio
    Decks: Garrard 301 Martin Bastin reworked/plinthed with Fidelity Research FR64fx
    Garrard 401 in eng Ferenc Lazar solid wenge plinth with SME 3012/2
    Cartridges: SPU Spirit/ Koetsu Black revisited by eng. Salai/ Miyajima Shilabe
    Step Up Transformers: Tango MCT 999/ Ortofon T-5000/ Lumiere SUT
    Digital: Shigaclone by eng. Ferenc Lazar with Lampizator Amber II
    Wires: of sufficient length
    I'm Adrian.
    My October birthday present... The Reed...
    Technics SP10 mk2
    Miyajima Shilabe cart
    Hashimoto HM-X SUT
    The Truth linestage
    Cary 805c SET amps
    Audio Note ANe-SPX speakers
    Lovely quality in those. I like quality engineering
    I'm Gary.
    Your headline got me intrigued for a second, being stupid, I read IKEA ....doh
    I'm intrigued to learn more about the 'on the fly' azimuth adjustment. That has to be a first for any arm.
    I'm Hugo.
    I don't know about it being a 'first' but it's simply effected by moving the little lever above the arm tube, which has the effect if rotating the bearing cradle by small degrees. That's possible because of Reed's use of magnets in both vertical and horizontal planes. I do like intuitive thinking and when it's implemented so beautifully, like here, you just have to be impressed. These Reed tonearms are quite clearly designed and made by talented engineers who also appreciate the need for sound ergonomics (not something that is always the case in audio!).
    Yes, by studying the photo in detail I worked that out, and it could only be done if magnetic bearings are used.
    You say it's not the first arm to have azimuth adjustment 'on the fly'. What others are/were there?
    I'm Hugo.
    I'm not saying that the Reed arms are not the first designs with this sort of adjustment - I simply do not know of others, but they may well exist (or have existed). Adam Smith would know in an instant!
    I'm Adrian.
    I'm pretty sure triplanar allows adjustment of everything during play. The Reed however looks a lot sexier and is reported to be sonically superior - but then I'm a fan of wooden wands.
    Technics SP10 mk2
    Hashimoto HM-X SUT
    The Truth linestage
    Cary 805c SET amps
