Hi People
Opinions please for people considering a entry into Reel to Reel
Any advice on what machine to buy and why
I'm Allen.
Hi People
Guessing you wont get a lot of choice at that price that works so i,d say an Akai. Good starter deck, and where i am.
I'm Allen.
I,m guessing a 4000 series. Think the bigger one would be more expensive. I.ve a 4000d i think. Decent player for money, although needs a little attention now it still works ok. They will also stand on end happily. Twin speed 4 track. A decent starter. You might get a Sony too.
I thought you were already into r2r Al
Hi-fiHangar are selling a Sony 377 pretty cheap just now. Rewind isn't 100% but plays and records fine.
http://www.ebay.co.uk/itm/201865381978
If interested it's worth phoning the shop direct 😉
I had to edit my thread as the A77 had sold, nearly bought it myself at £275 plus postage.
http://www.ebay.co.uk/itm/192138874419
Maybe in need of belts... decent machines the sonys.
None?
I don't want to put you off All, but I just don't get the R2R thing. What you record will only (hopefully) be as good as the source, so unless you own a library of original recordings transcribed straight from a master tape, I can't see the benefit. Unless of course, one just enjoys R2R as an entertaining plaything and something to tinker with.
I'm Charlie.
Al,
I'm not sure that you can get anything really worthwhile for £250, unless you're a technical whizz and have a workshop at home. 3-4 years ago, you could have got a Revox A77 for that sort of money, but not now. Sure you might get an Akai 4000DB, which would be a bit of fun. You might also be able to play some 7.5 IPS 4 track commercial tapes. A serviced domestic R2R running at 7.5 IPS will sound better than decent cassette, but few vintage domestic machines are running at their best. But as Geoff says, the R2R thing is all about the highest quality, which can outshine even the most expensive and exotic turntable system for relatively small amounts of money for the hardware (but not the software).
Charlie
